I am getting error 1638 (Another version of the prodict is already installed) when trying to update my installation. I am using InstallShield Developer 7.04 and I am using setup flags: REINSTALLMODE=voums REINSTALL=ALL.
Product and Upgrade codes are identical for the old and new setup, the package code and version differs. The update setup was trimmed down in size a little bit by using release flags to filter out some features.
Any ideas?
Regards,
Bernd
Error 1638
bholz
, Sep 06 2002 09:12
Posted 06 September 2002 - 17:18
Are you setting REINSTALLMODE in setup.ini or on the comamnd line? (this should work) Or in the property table (this will NOT work)
Posted 09 September 2002 - 07:10
Stefan,
I am setting the option in the release view in ISD 7.04 in the field "MSI Command line options". I am building a single executable. If I look at the extracted files I see the settings in set setup.ini file.
Regards,
Bernd
Regards,
Bernd
Posted 10 September 2002 - 11:12
Very strange - this should work.
Did you try an uncompressed CD-ROM build for testing purposes?
