Hello!
I try to build MSI database with Visual Studio .NET Installation Wizard. It contains some Custom Actions not familiar for me.
Visual Studio .NET Custom Actions
AntonS
, Nov 26 2004 15:07
Posted 26 November 2004 - 15:07
| Type 1 Custom Action calls a dynamic link library (DLL) written in C or C++ DIRCA_CheckFX VSDCA_VsdLaunchConditions WEBCA_CreateAppRoots WEBCA_CreateURLs WEBCA_EvaluateURLs WEBCA_EvaluateURLsMB WEBCA_EvaluateURLsNoFail WEBCA_GatherWebFolderProperties Type 19 Custom Action displays a specified error message ERRCA_CANCELNEWERVERSION ERRCA_UIANDADVERTISED Type 307 ( I suspect Type is calculated: 51 + msidbCustomAction TypeOncePerProcess) DIRCA_NEWRETARGETABLEPROPERTY1.2F63C82261CB4334895E044F38F53D66 WEBCA_NEWWEBPROPERTY1PORT WEBCA_NEWWEBPROPERTY1VDIR WEBCA_TARGETPORT WEBCA_TARGETVDIR Type 1281 (I suspect Type is calculated: 1 + msidbCustomAction TypeOncePerProcess + msidbCustomAction TypeClientRepeat) WEBCA_RollbackApplyWebFolderProperties Type 1537 (How is calculated Custom Action type?) WEBCA_ApplyWebFolderProperties |
Please, eliminate for me intention of this Custom Actions.
I find no information about MSVBDPCADLL.DLL, called in most of above CA.
Posted 26 November 2004 - 23:02
hi,
these CAs seem to be native to VS.NET and therefore are not suported. What this means is basically that VS needs them for managing virtual directories in its web projects and you are not suppose to use them on your own. But again, who cares what is allowed and whats not... take a look here http://nant.sourcefo...p... build file
That is a nice example of using all the WEBCA actions, their meaning is in their names i think...
As for the others, my guess is:
DIRCA_CheckFX - checks if .NET framework is installed on the target machine
VSDCA_VsdLaunchConditions - same as LaunchConditions, but checks for specific VS.NET components.
ERRCA_UIANDADVERTISED - checks if the product is advertised. if it is, it will prevent execution of the installation in full UI mode
ERRCA_CANCELNEWERVERSION - cancel installation if the newer version is detected (typically executed after FindRelatedProducts action).
There is no such thing as MSVBDPCADLL.DLL, instead you should be looking for MSVBDPCA.DLL (http://www.biacreations.com/MSVBDPCA.DLL) as MSVBDPCADLL is just a handle to the file.
Hope this helps...
Alex.
Hope this helps...
Alex.
Edited by Volynkin, 26 November 2004 - 23:02.
