I have created an msi installation with Installshield 2011. With one minor hitch I am able to deploy it using Windows 2008 GPO to a domain user.
The problem occurs at the end of the installation where I have it launch an executable (VC++ redistributable). An error message pops up saying the user doesn't have administrative privileges to run that executable file. Is there a way around this?
I could install with elevated privileges, but I would prefer not to do that.
If I try to install the VC++ redistributable as an Installshield prerequisite, I am not able to create an MSI installation file. A setup launcher is required to install prerequisites. I am not able to deploy installations created with a setup launcher.
Any ideas?
Launching executables from MSI Installs
rajkulkarni
, Jun 02 2011 14:52
Posted 04 June 2011 - 11:48
Use the appropriate merge module in this case.
But installation of vcredist, via exe or merge module, will need admin privileges. There is no workaround.
Workaround through other approaches:
Using MFC as Static Library in the application. Although this increases size of the app, in the end you would not need the vcredist. This is when it only depends on MFC.
But similar step can be taken for other run-time libraries.
Look at this for advanced info:
http://msdn.microsof...-US,VS.80).aspx
Edited by MSIYER, 04 June 2011 - 11:49.
Posted 10 June 2011 - 10:03
If you need to run an executable from a custom action with elevated privileges, the custom action must be scheduled "deferred in system context" and sequenced between InstallInitialize and InstallFinalize in the InstallExecute sequence.
Posted 11 June 2011 - 10:46
Stefan:
Please correct me if I am wrong.
I feel launching vcredist.exe in the "deferred in system context" will not be successful as the msiexec.exe server process would already be busy with the base product installation and the mutex would not allow the vcredist installation to happen.
UI Sequence is where we can invoke vcredist synchronously, wait for it to finish and then proceed with base product install.
Posted 14 June 2011 - 11:17
| I feel launching vcredist.exe in the "deferred in system context" will not be successful as the msiexec.exe server process would already be busy with the base product installation and the mutex would not allow the vcredist installation to happen. |
I didn't analyze the vcredist.exe. If it is a msi setup indide, then you are right, it won't work thatw ay. Thanks for mentioning this.
| UI Sequence is where we can invoke vcredist synchronously, wait for it to finish and then proceed with base product install. |
The UI sequence typically runs with restricted permissions. And in a silent setup (or basic UI) it will be skipped alltogether.
So the recommended solution would be a prerequisite.
Posted 14 June 2011 - 13:07
Thank you Stefan.
vcredist.exe is a self-extracting exe that installs VC++ runtime library redistributables through an msi package.
