I am trying to determine the domain of the machine running an install. To do this I am using the ipconfig /all command routed to a text file, but when done from within Install Shield the file is not created, and the output is not routed anywhere.
nReturn=LaunchAppAndWait("ipconfig","/all > c:\\temp.txt",WAIT);
nReturn=FileGrep("c:\\temp.txt", "Primary Dns Suffix", svReturn, nvLine, RESTART);
This works fine from the command line, and the grep runs fine if the file is created from the command line. Any ideas?
Thanks in advance!
Capturing output from command line
prozacrefugee
, Oct 23 2002 20:00
