There is a known issue (Document ID: Q110774) where the Add/Remove Programs applet hangs during uninstall if you launched an application during setup (typically via LaunchAppAndWait), even with the LAAW_OPTION_NOWAIT option. This is because the ARP applet waits until the setup process that it launches and any other child processes complete. The suggested solution if you have to use LAAW_OPTION_NOWAIT is to create a wrapper executable that would just launch the application then exit. I cannot get this to work. Has anyone else come across this issue? Could you send sample code for the exe wrapper? I've used CreateProcess and ShellExecute, but to no avail. I guess IS still considers everything to be a child process.
Add/Remove hangs
frobisher
, Sep 14 2004 01:31
