I'm a beginner with msi and I'm getting really lost. I want to do a little installation that only have two files. I want to execute one file with the other one as parameter but I don't want to install them to the HD,I only want to execute. I' ve seen that there's a custom action that I can use to execute directly from the cab but I can't manage it. How could I do it? I'm using ISWI 1.5
Thank you all for your help
Executing from CAB
Miquel
, Jun 08 2001 12:54
Posted 15 June 2001 - 01:54
If you want to excute one on in your installation and use the other file as a parameter that is passed to the file being excuted and not install either file onto the local system you will have to use the Binary table in the Power Editor so that the installation can see the files in the installation package without having them installed on the local server.
TDG
