I have built an application and now I have finished a simple installation using installshield 6.2, that shows the user the License and then installs the application in a standard directory.
My application is using an SQL Server d/b, so I have to install the MSDE (what I want to do is run the SETUP.EXE in the MSDE directory), which relatively is the ../MSDE/SETUP.EXE file.
Could you answer this question for me please, and if you have time, just to let me know how I can deploy/attach my d/b from a backup set (or something else). So, after the MSDE is installed, and after all my files are installed, do the following:
1. Start the SQL Server agent
2. Install my d/b locally
3. Create an SQL login for that d/b
Thanks for your time
Georgios Markatatos
g.markatatos@elyros.com
