Hi
I'm trying to automate post-build updates to the MSI file. The UPDATE query
worked fine, but I have an error on the INSERT query.
The INSERT query is as follows:
INSERT query using WiRunSQL.vbs
eelisdotnet
, Jul 13 2005 14:28
Posted 13 July 2005 - 14:28
Cscript WiRunSQL.vbs Setup.msi "INSERT INTO Registry (Registry.Registry,Registry.Root,Registry.Key,Registry.Name,Registry.Value,Registry.Component_) VALUES ('R__ConfigFileRegistry','1','Software\[Manufacturer]\[ProductName]\Config','[_C764143EC7AD42D1BE743AC87204C0E0]','C__00FBFDC77D25406F9F3B6C49E297693F')" |
The error is :
Msi API Error 80004005: OpenView,Sql
1:2227 2:Setup.msi 3:Key 4: INSERT INTO Registry ... (all the query syntax)
Error 2227 is defined as: Database: [2]. Invalid identifier '[3]' in SQL query: [4].
in the following MSDN
I couldn't track any invalid identifier in the 'Key' value nor in
'Registry' value on the query. Furthermore, the raw was successfully added to
the Msi using Orca and hard-code.
Any suggestions..... thanks!
Posted 13 July 2005 - 18:02
Try this instead:
| ´Registry´.´Key´ |
KEY is a SQL keyword so this might clash with the column name.
Here's a quote from help topic SQL Syntax:
| To escape table names and column names that clash with SQL keywords, enclose the name between two grave accent marks `` (ASCII value 96). If a column name must be escaped and is qualified as {tablename.column}, then the table and the column must be escaped individually as {`tablename`.`column`}. It is recommended that all table names and column names be escaped in this fashion to avoid clashes with reserved words and gain significant performance. |
Posted 14 July 2005 - 07:32
Thanks Stefan!
It was indeed the grave accent marks. I used first the apostrophe (single quote) char that should be used only for the Values.
Well, I think it should be noted more clear in the MSDN.
guess I wasn't paying too much attention to that tiny grave accent...
Cheers!!!
Cheers!!!
