Any ideas as to finding if a process is running?
FindWindow is not working, I believe it won't work as the process is just a dos program...
Matt
Find if a process is running
thompsonson
, Apr 29 2004 16:36
Posted 30 April 2004 - 09:52
Does the process run as a service? Maybe you can check the service status?
What process are you trying to check?
There is a way inside the Windows API to find running process's you will just have to look up the correct function.
Im pretty sure there is not any code included in Install Script that will do this.
