Help, I am trying to populate a list box with the SQL Servers names using SQLDMO Application in a VBScript Custom Action. I am using InstallShield Professional – Windows Installer v2.03. I have created the list box on a dialog and I have a button to retrive the SQL Server names (DoAction to call Custom Action). I got the example from here (ListSQLServers.vbs) but I can’t seem to get it to populate the list box. Any suggestion would be appreciated. I have included the vbs code below.
Function ListDisplay()
Set objInstaller = Session.Installer
Set objDatabase = Session.Database
' open and execute a view to the ListBox table
Set viewlist = objDatabase.OpenView("SELECT * FROM `ListBox` WHERE `Property`= 'LISTBOXPROP'")
viewlist.Execute
r = 0
' ListBox record fields are Property, Order, Value, Text
Set reclist = objInstaller.CreateRecord(4)
'Use the SQL DMO Application Object to find the available SQL Servers
Set oSQLServerDMOApp = New SQLDMO.Application
Set namX = oSQLServerDMOApp.ListAvailableSQLServers
For i = 1 To 4 'namX.Count
reclist.StringData(1) = "LISTBOXPROP"
reclist.IntegerData(2) = r
reclist.StringData(3) = namx.item(i)
reclist.StringData(4) = namx.item(i)
' insert the temporary ListBox record
viewlist.Modify 7, reclist
r = r + 1
reclist.ClearData
Next
' clean up
viewlist.Close
Set oSQLServerDMOApp = Nothing
Set namex = Nothing
' return success to MSI
ListDisplay = 1
End Function
Populating a ListBox with a Custom Action
ConfigControl
, Apr 26 2004 13:24
Posted 26 April 2004 - 19:19
looks like you forgot to declare a NameList for the SQL Server...
Dim oApp As New SQLDMO.Application
Dim oNames As SQLDMO.NameList
Dim iCtr As Integer
Set oApp = CreateObject("SQLDMO.Application")
Set oNames = oApp.ListAvailableSQLServers()
For iCtr = 1 To oNames.Count
List1.AddItem oNames.Item(iCtr)
Next
Set oApp = Nothing
Set oNames = Nothing
I create a blank project create a listbox and put the above code into the FormLoad event and I get a list of SQL Servers that are on my current domain... just replace the line:
with your code to add to the list box....
Dim iCtr As Integer
Next
Set oApp = Nothing
Posted 26 April 2004 - 19:57
Thanks, but I am trying to use VBScript in a Custom Action and I don't have a FormLoad event. Yes, I have been able to this to work in VB but for some reason VBScript does not like the Dim As statement (crashes). I don't have a debugger so all I have been able to do is place MsgBox in various places in the code so I could fine where and on what the code crashed.
Jim Copenhaver
Jim Copenhaver
ConfigControl
