Good point about the reboot. However, these guys make the rules and could easily come up with something better than a folder where you are not even guaranteed that basic access rights exists (granted this problem only seems to occur if the user manually messes with the NTFS rights, but a folder straight under root is going to be messed with).
Some ways to get more space on C:\:
* move the page files to a different drive. I normally still leave a small page file on C:\ even if I move it, because I have experienced windows systems that won't boot because they cannot find the page file (for example if drive letters change).
* Other things you could do would be to move the user's temp folders to a different drive (I have never done this), and
* obviously map My Documents to a different network share, but I am 100% sure this is done already.
* Finally enabling drive compression is always a last resort
* It may be possible to gain some space by changing the cluster size of the NTFS file system on that drive, but you need special tools for this, and it is hard to get an improvement this way unless the drive is full of either small or big files.
Edited by Glytzhkof, 08 July 2004 - 08:57.
