I have three questions:
1. How can I prevent certain files in my installation from being
included the cab-file?
2. Is it possible to install different files depending on the language selected? For exemple, if I choose german installation i want just the german .hlp-files to be copied to the target dir..
3. If I have an autorun i which the user selects the language,
can I "tell" Installshield to use the same language? I guess by
overriding the routines that Installshield uses to determinate the install language, or something.
(Im using Installshield 6.0)
Tricky questions?
jive02
, Mar 13 2002 22:13
Posted 14 March 2002 - 14:10
1. In the media build wizard there's an option where you can select that some components should not be compressed. I'm not if that is available in 6.0 or was added in a later 6.x release.
2. There's a language property in the file groups.
3. You can pass the language to setup.exe using the -l command line switch.
