I have an InstallShield DevStudio 9 install project that creates a setup.exe as a network downloadable image. This installer requires admin rights to work. In the installer there is an install condition to check that the user has admin rights.
When I run this installer as a .msi file it does just what I want.
When I run it as an exe it pops up a few errors. It says it can't write to c:\WINDOWS\Downloaded installations\<GUID>. It than pops up a directory browser for you to choose a location. Then I get another error about creating an error log file.
How do I control setup.exe behavior?
The error log it complains about shouldn't be written to until we get to the first custom action in the sequence. Shouldn't install conditions have been checked by then?
Thanks for any insight you can provide.
-Bob
Errors from InstallShield's setup.exe
donjacour
, Apr 15 2004 01:38
Posted 15 April 2004 - 06:54
Do you have the correct permissions to write to the area that the setup wants to use?
What are the exact errors that pop up?
Possibly search the install shield knowledge base for clues.
Posted 15 April 2004 - 21:07
The setup.exe runs and extracts your setup files before your .msi launches, so your check is too late.
