Afternoon everyone,
IS 12 Sp2 NewBe here.
Here's a little background.
Basic MSI.
I created a custom dialog that has two check boxes on it.
The first check box has a property named CB1.
The second check box has a property of CB2.
I have two components named C1 and C2.
The first component has a "Condition" of "CB1".
The second component has a "Condition" of "CB2".
Both components are associated with a feature named F1.
Each of the above components installs a shortcut.
When the application INSTALLS for the first time, I can check either checkbox (or both) and the appropriate shortcuts are created on the pc.
Here's my problem:
Let's say I install the application for the first time and I click on the "CB1" check box.
The CB1 shortcut is installed.
Then I turn around and re-install the same application.
I choose the "Modify" option.
The Feature (F1) appears to to already selected. (Because it is already installed.)
And this time I click on the "CB2" checkbox from my custom dialog. (Which appears following the "Features" dialog.)
The UPGRADE dosen't generate any errors but I DON'T get the "CB2 shortcut installed on my pc.
I can't figure out what the heck I'm doing wrong.
Can I ask for some suggestions on how I might fix this ?
I should be very greatful.
Ray in Wisconsin
Components not installed on upgrade
RayKode
, May 23 2007 21:22
Posted 25 May 2007 - 12:46
Hello again everyone.
Thanks to thoes who took the time to read my posting.
InstallShield support was not able to help me with my issue either.
I chose instead to accomplish my goal with the following .....
1. Create a new Feature called "AllShortCuts"
2. Create a sub feature of "AllShortCuts" called "Shortcut One"
3. Create a sub feature of "AllShortCuts" called "Shortcut Two"
4. Create a sub feature of "AllShortCuts" called "Shortcut Four"
Then the user can add or remove the various shortcuts by simply invoking the Modify option via the Control Panel/Add-Remove program/Change selection.
Done.
It was easy to accomplish and required less work than creating and referencing properties associed with a custom dialog.
Thanks again everyone.
Take care.
Ray in Wisconsin
Done.
Take care.
Ray in Wisconsin
Posted 29 May 2007 - 18:12
Problem with your original approach was that component conditions are evaluated during CostFinalize which is before your dialogs. Having separate features for those shortcuts is a good solution. If you prefer checkboxes, make the features invisible and add a dialog with check boxes. On the "Next button of that dialog add control events AddLocal and Remove to select or deselect the shortcut's feature based on the checkbox selection.
