System Search entries invisible
kukumar
, Feb 05 2007 14:50
Posted 05 February 2007 - 14:50
I am using the Install Shield 12 Premier Edition and I wonder if other people have similar problem like me.
When I am using the System Search Functionality everything works fine with defining the searches etc. . But when I leave this Editor and come back to it later (Closing and Opening the project again) all entries are gone although they still exist in the appsearch table.
This malfunction appeared in several project (only in few it works normal)
Does anybody know what is the reason for that?
Posted 05 February 2007 - 17:00
Sorry,
i found the reason!
If you rename the _signature in one of the the DrLocator, RegLocator or AppSearch Tables you must assure that the _signatures must be changed in other tables as well
i found the reason!
