I am facing one issue while installing one of our product which is in installshiled 5.5 Professional edition.
system environment PATH variable is having more then 1024 characters. If i install component that PATH variables are deleting and only installing component path will be present. it is working fine till 1024 character.
i installed the below mentioned microsoft hotfix which has a fix to increase the character limit to 2048 charcters in windows 2003 sp1 machine and installed one component and in PATH everything is getting deleted, only wat ever i have installed now is remaining in PATH Variable..
http://support.microsoft.com/kb/906469
I also tried windows 2003 sp2 machine.. same problem persist..
Thanks in advance
Anu
Edited by anupamasjce2005, 03 May 2011 - 07:38.
