I am looking for a function in InstallShield 5.1 Professional edition, which can tell me whether a folder icon already exists or not.
For example: -
Folder icon: -
Start --> Program Files --> XYZ ---> ABC
My installer should check whether ABC icon exists on the machine or not. If it exists on the machine, then create
Start --> Program Files --> XYZ ---> ABC1
else create
Can you please tell me how can i achieve this?
Aseem Bansal
check whether folder icon exists
aseembansal
, Jul 04 2003 07:49
Posted 04 July 2003 - 13:28
Try the Is function.
This should help you to find whether the link/folder exists.
If not, you can create it with the following command, if it exists, create a different one.
If ABC and ABC1 exist ...
You can code a repeat- or while-phrase that changes the number when the link already exists, until ...
| if( Is( FILE_EXISTS, FOLDER_STARTUP ^ "ProgramABC.LNK" )) then ... if( Is( PATH_EXISTS, FOLDER_STARTUP ^ FOLDER_XYZ )) then ... |
Gruß / regards
Thomas
Thomas
