I am trying to build a msp and getting the below error. Can some one help me? I am completly blocked. Not able to understand why this is not working.
MSI is not having upgrade table itself. However it has package code and product code.
Please help.
Boyz22z
INFO: Using Pcp Path: D:\BLRIDCRAGHUTEST\depot2\Titan\win32_x86\release\logs\packages\LCMFP1\LCMFP1.1.pcp.
INFO: Using Temporary Directory: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\~pcw_tmp.tmp.
INFO: Passed all of the main control parameter validation to PatchWiz, now calling the next 5 phases.
INFO: Phase I: Entered validation and processing phase.
INFO: Validation of Pcp.
INFO: MinimumRequiredMsiVersion is 100.
INFO: SEQUENCE_DATA_GENERATION_DISABLED is 0.
INFO: ListOfPatchGUIDsToReplace is .
INFO: ListOfTargetProductCodes is .
INFO: MsiFileToUseToCreatePatchTables is .
INFO: PatchGUID is {79D51862-0947-4395-B72F-F3BEA119CE1C}.
INFO: PatchOutputPath is D:\BLRIDCRAGHUTEST\depot2\Titan\win32_x86\release\patches\lcm\package\LCM.msp.
INFO: PatchSourceList is .
INFO: PATCH_CACHE_DIR is .
INFO: AllowDualPatch is 0.
INFO: AllowProductCodeMismatches is 0.
INFO: AllowProductVersionMajorMismatches is 0.
INFO: ApiPatchingSymbolFlags is 0.
INFO: DontRemoveTempFolderWhenFinished is 1.
INFO: IncludeWholeFilesOnly is 1.
INFO: PATCH_CACHE_ENABLED is 0.
INFO: OptimizePatchSizeForLargeFiles is 0.
INFO: META_DATA_GENERATION_DISABLED is 0.
INFO: TrustMsi is 0.
INFO: AllowLaxValidationFlags is 0.
ERROR: Failed to fetch from a view
ERROR: The Last Error Received is: 259
ERROR: UpgradedImages.Upgraded = 'LCMUI1': UpgradeCode is not a valid GUID.
ERROR: The Last Error Received is: 0
ERROR: Internal PatchWiz Error occurred.
ERROR: The Last Error Received is: -1072803463
MSP error : UpgradeCode is not a valid
boyz22z
, Jan 07 2009 08:09
Posted 17 December 2009 - 21:32
boyz22z -
Did you ever get this figured out? I'm hitting the same problem.
Posted 18 December 2009 - 11:32
Please copy & paste here the value of your UpgradeCode property.
