I'm experiencing very long delay when uninstalling my package. I can see in the log the following lines:
MSI (s) (10:EC) [15:52:24:407]: Note: 1: 2205 2: 3: _RemoveFilePath
MSI (s) (10:EC) [15:56:25:767]: Note: 1: 1402 2: HKEY_CLASSES_ROOT\.NET Live Explorer 3: 2
It seem to take 4 minutes to execute the first line.
I've seen somewhere that the error code 2205 means that the table is not present. Why does it take 4 minutes to check for that?
I'm running the package on Vista with admin priviledge.
Thanks in advance,
Jacques.
Long delay...
BourqueJ
, Oct 15 2007 21:25
Posted 16 October 2007 - 15:43
During whcih action do you get these lines?
I think the messages are written at the end of the action, so it would be the action that produces the 1402 result which takes so long. 1402 = Could not open key: [2]. System error [3]. I guess it's reading registry entires (maybe not loging those that succeed).
Posted 16 October 2007 - 16:46
Hi Stefan,
the action in question is InstallValidate.
I must mention that this project is build with InstallShield and was upgraded from several previous version.
I've noticed that there is a lot of broken entries in the tables (files and folders at least) that the IDE doesn't seem to be able to clean up.
I don't know if this can be the cause of the problem.
Thanks again,
Jacques.
Thanks again,
Jacques.
Posted 17 October 2007 - 12:40
I could. Please fix any broken table entries, and perform validation on the built msi file.
Posted 31 May 2009 - 07:36
thanks
that's useful for me.
If I had only known, I would have been a locksmith.
dofus kamas
dofus kamas
