I have external DLL which I load and access its functions inside the script.
I have doen it successfully in IS5.5.
Since I am upgrading to IS6.31 , same DLL functions are not working.
e.g. Dll name : MyDLL
Function : MyFunction(STRING str)
UseDLL is working fine : DLL is loaded properly.
When accessing function , MyFunction(str) , it displays error message "an error occured while launching the setup.(0x80040704)".
Is there anything changed from IS5.5 to IS6.31 which is giving problem ?
Is there any special requirement on DLL side ?
I would appreciate your help.
Problem in accessing DLL functions in IS6.31
pari
, Mar 21 2002 01:32
Posted 21 March 2002 - 10:04
Hi Pari,
The problem might be thta IS expect the function to have its argument passed by reference. To circumvent this you can try this:
prototype MyDll.Myfunction(BYREF STRING);
and use it in your scripts as
svString = "blahblah";
MyFunction(svString);
(so not! MyFunction("blahblah"); )
HtH, Ide
HtH, Ide
Posted 21 March 2002 - 15:02
Hi Pari,
some days ago I experienced just the same problem: using a function inside of a DLL worked fine with IS 5.5 but failed with 6.31.
I succeeded with modifying the declaration:
Instead of (5.5 like)
prototype SHORT MyDLL.Function(STRING);
write this (successful with 6.31):
prototype cdecl SHORT MyDLL.Function(BYREF STRING);
//the cdecl is the important thing!
Regards,
Eberhard
Regards,
Eberhard
Posted 21 March 2002 - 16:26
besides the problem with cdecl IS has changed the default behaviour of STRING parameters in function prototypes.
In IS 5.5
prototype INT my_dll.tralala(STRING);
means that STRING is passed byref.
In IS6.x
means that STRING is passed byval. You have to explicitely define
prototype INT my_dll.tralala(BYREF STRING);
to achieve the same results.
Regards,
Marko
In IS 5.5
In IS6.x
Regards,
Marko
Posted 21 March 2002 - 17:04
Dear Friends,
1. I was already using BYREF which is required.
2. I was not using cdecl. I changed my defination with cdecl as suggested and It worked.
Thanks a lot for all of you who have replied.
Keep up the good work.
Cheers,
pari
Cheers,
pari
Posted 21 March 2002 - 18:14
Inside the C or C++ DLL I declare and functions to be accessed by InstallShield as follows:
extern "C"
LONG WINAPI MyFunction(LPTSTR);
This prevents the name from being mangled and it declares it to use the PASCAL calling convention. I also add each function name (case sensitive) that is to be exported to a module definition file (.DEF).
Within the header file the InstlalShield includes, the prototype would be as follows:
protoype MyDll.MyFunction(BYREF STRING);
I do not need the cdecl and I do not need to tell it it is returning LONG, since the function is doing that already and that is apparently the default assumption of InstallShield.
Then I do not need to change the header file or the DLL for either version of InstallShield.
extern "C"
