There is some way of uninstalling without running the initial uninstall sequence? I've tried to delete the Uninstall key from registry, but there is no result.
Please help me! Thanks.
Posted 24 August 2001 - 07:22
Posted 24 August 2001 - 09:02
1. The first is to use a utility you should have called MSIZAP. You can use this to clean up the msi registry for a particular installation. Then you just remove the files and registry keys manually.
2. Edit the cached msi file and remove the offending CA. This has the advantage of a more orderly uninstallation, removing files and registry.
Cached installations can normally be found in the directory C:\WINNT\Installer you will find a number of files with names like '103b1da.msi' Move the cursor over the filename in explorer and a tooltip will tell you the contents. When you have found yours open it with ORCA. Select the InstallExecuteSequence find your CA and delete it (or add a never true condition). Save it. Run the Uninstall.
Hope this helps.
(You can find the name of the cached msi file more directly. It is in the registry under HKLM\Software\Microsoft\Windows\CurrentVersion.\Installer\LocalPackages and an obsfucated version of your ProductID guid.)
