I'm working on our new product install which will the version 10.0 family. We are coming from 8.6 and earlier. When I run the upgrade from 8.6.x to 10.0.1 all works as planned. Old version detected and removed and the latest is put in place.
I thought I would look ahead and ensure a Major Upgrade in our new version family worked as expected. When I try moving from 10.0.1 to 10.0.257, the old is not removed and I see two instances in Add Remove Programs.
I can't for the life of me figure out what is wrong. I bumped the ProductVersion, obviously. Changed the ProductCode and PackageCode and changed the MaxVersion field value in the Upgrade Table.
All I see in the Log is Not Related and I don't see the ISFOUNDCURRENT property set in the second log. I've attached the 8x to 10 log and log from the 10.0.257 upgrade. To see images of the Upgrade view settings, you can see my Flexera Software post here
I even tried changing the Upgrade Code and creating a separate Upgrade table entry for the v10 family, but that didn't work either. On this new entry I tried including the MinVer, but to no avail.
I just can figure this out. It almost seems there is a problem using 10 versions at this point, but that's absurd.
Any help in this would be greatly appreciated!
Thanks MUCH in advance!!
Edited by Superfreak3, 20 April 2012 - 16:41.
