Errors while building a Basic MSI project having installscript custom
Posted 18 October 2013 - 07:40
Posted 18 October 2013 - 18:34
I'm not sure of the exact problem. I've seen and read about a few other similar instances. The commonality between the problems seems to be file locks on the files trying to be read. The particular instance I have personally seen was when my virus scan software had locked a file for scanning while I was building. If I recall rebooting resolved my issue but I've read other posts where recreating the project directory in a new location resolved the issue. I think the important thing to consider when looking at resolving this issue is trying to determine what is preventing read access to these files.
Posted 21 October 2013 - 07:45
Hi ,
I had a project which was giving this error and rebooted my PC and then moved my project to a new location and it worked fine. But i am getting the same error again for a different project and this solution of rebooting or moving the project to a different location is not working. Any other suggestions on how to get rid of this?.
Regards.
Balaji
Posted 24 October 2013 - 04:32
Can anyone please help me on this, still not able to resolve this issue.
Regards,
Balaji
Posted 25 October 2013 - 10:38
Does D:\New Folder\Script Files\Setup.inx exist? Did you check its permissions?
Try running Process Monitor from sysinternals.microsoft.com . It should tell you if there's an access conflict and what the exact error is.
Posted 30 October 2013 - 11:48
Hi Stefan,
Yes setup.inx is generated at runtime and its present at the mentioned location , it doesn't have any access restrictions and the process is also not locked. I monitored using process monitor and it seems to be fine. Not sure what is causing the issue. Any other way to debug this?
Posted 30 October 2013 - 17:34
Not really. Are you using the latest version of InstallShield? If not you could try a IS 2013 Evaluation copy.
Posted 31 October 2013 - 09:33
The build was failing in my licensed version of 2010 , i downloaded the trail copy of 2013 and tried building the project using 2013 and it builds without any errors. If i install the patches for 2010 will it help? , now i am sure its not the problem with my project.. Kindly advice.
Posted 06 November 2013 - 09:44
Hmm, I don't know. Try installing all Service packs and Hotfixes for 2010 to see if that helps.
