From just about any log file, you can see:
******* Action:
******* CommandLine: **********
and later on you'll also notice that some of the Command Line is logged... (een if this isn't what you've put on your command line)
MSI (s) (DC:D0): Command Line: CURRENTDIRECTORY=P:\ CLIENTUILEVEL=3 CLIENTPROCESSID=666
Is there anyway I can use this information in the form of a property? CommandLine isn't recognised in the SDK, yet it "seems" to appear in the log. I'm after a way to track what properties were used at the time of install.
TIA,
James
Obtaining the CommmdLine property
SourceList
, Aug 17 2004 11:14
Posted 18 August 2004 - 07:24
This has always puzzled me as well. Its hard to tell if Windows Installer is actually storing this commandline somewhere in a temporary table, or not storing it at all and just grabbing it from the commandline.
Maybe someone else knows?
Posted 18 August 2004 - 09:13
Sorry if I'm stating the obvious: Any properties you pass in on the command line when your launch the installation are available as properties.
I don't know of any way to retrieve the full command line.
The second sample is what the client process (UI secquence) passes to the server process (execute sequence).
Posted 23 August 2004 - 14:17
| QUOTE (Stefan Krueger @ 2004-08-18 09:13) |
| I don't know of any way to retrieve the full command line. The second sample is what the client process (UI secquence) passes to the server process (execute sequence). |
Thanks - shame there isn't a way to get the command line, I may have to see if we can get this done by the deployment tool.
Cheers!
