It's not clear how the modify choice (in maintenance setup window) works.
From InstallShield help:
<<Install individual components that were not previously installed, and uninstall individual components.>>
Let me start with an example
1. I install a three-components setup
2. I start maintenance, I choose modify
3. a select-component window appears. The heading says:
<<Select components you want to install, and clear the components you do not want to install>>
4. if I select comp 1 and clear comps 2 and 3 what's happen?
comp1 will be reinstalled --> that's for sure
a) comps2,3 will only not be reinstalled (they remain the old two) or...
if
Thanks.
Ciao, Giuseppe
