The installation returns a messagebox that just says "Unkown error -1". It is a Windows 2003 server, sp1, windows installer 3.1. Any ideas? Here is the log:
=== Logging started: 4/12/2006 13:22:49 ===
Action 13:22:49: INSTALL.
Action start 13:22:49: INSTALL.
Action 13:22:49: DIRCA_CheckFX.
Action start 13:22:49: DIRCA_CheckFX.
Action ended 13:22:49: DIRCA_CheckFX. Return value 1.
Action 13:22:49: AppSearch. Searching for installed applications
Action start 13:22:49: AppSearch.
Action ended 13:22:49: AppSearch. Return value 1.
Action 13:22:49: VSDCA_VsdLaunchConditions.
Action start 13:22:49: VSDCA_VsdLaunchConditions.
Action ended 13:22:49: VSDCA_VsdLaunchConditions. Return value 1.
Action 13:22:49: LaunchConditions. Evaluating launch conditions
Action start 13:22:49: LaunchConditions.
Action ended 13:22:49: LaunchConditions. Return value 1.
Action 13:22:49: CCPSearch. Searching for qualifying products
Action start 13:22:49: CCPSearch.
Action ended 13:22:49: CCPSearch. Return value 1.
Action 13:22:49: RMCCPSearch. Searching for qualifying products
Action start 13:22:49: RMCCPSearch.
Action ended 13:22:49: RMCCPSearch. Return value 0.
Action 13:22:49: ValidateProductID.
Action start 13:22:49: ValidateProductID.
Action ended 13:22:49: ValidateProductID. Return value 1.
Action 13:22:49: DIRCA_TARGETDIR.
Action start 13:22:49: DIRCA_TARGETDIR.
Action ended 13:22:49: DIRCA_TARGETDIR. Return value 1.
Action 13:22:49: CostInitialize. Computing space requirements
Action start 13:22:49: CostInitialize.
Action ended 13:22:49: CostInitialize. Return value 1.
Action 13:22:49: FileCost. Computing space requirements
Action start 13:22:49: FileCost.
Action ended 13:22:49: FileCost. Return value 1.
Action 13:22:49: IsolateComponents.
Action start 13:22:49: IsolateComponents.
Action ended 13:22:49: IsolateComponents. Return value 1.
Action 13:22:49: VSDCA_FolderForm_AllUsers.
Action start 13:22:49: VSDCA_FolderForm_AllUsers.
Action ended 13:22:49: VSDCA_FolderForm_AllUsers. Return value 1.
Action 13:22:49: CostFinalize. Computing space requirements
Action start 13:22:49: CostFinalize.
Action ended 13:22:49: CostFinalize. Return value 1.
Action 13:22:49: WelcomeForm.
Action start 13:22:49: WelcomeForm.
Info 2898. VSI_MS_Sans_Serif13.0_0_0, MS Sans Serif, 0
DEBUG: Error 2826: Control Line1 on dialog WelcomeForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: WelcomeForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog WelcomeForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: WelcomeForm, Line2, to the right
DEBUG: Error 2826: Control BannerBmp on dialog WelcomeForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: WelcomeForm, BannerBmp, to the right
Info 2898. VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400, MS Sans Serif, 0
Info 2898. VSI_MS_Sans_Serif16.0_1_0, MS Sans Serif, 0
Action 13:22:49: WelcomeForm. Dialog created
DEBUG: Error 2826: Control Line1 on dialog EulaForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: EulaForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog EulaForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: EulaForm, Line2, to the right
DEBUG: Error 2826: Control BannerBmp on dialog EulaForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: EulaForm, BannerBmp, to the right
Action 13:22:52: EulaForm. Dialog created
DEBUG: Error 2826: Control Line1 on dialog FolderForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FolderForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog FolderForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FolderForm, Line2, to the right
DEBUG: Error 2826: Control BannerBmp on dialog FolderForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FolderForm, BannerBmp, to the right
Info 2898. VSI_MS_Shell_Dlg13.0_0_0, MS Shell Dlg, 0
Action 13:22:53: FolderForm. Dialog created
Action 13:22:54: FindRelatedProducts. Searching for related applications
Action start 13:22:54: FindRelatedProducts.
Action ended 13:22:54: FindRelatedProducts. Return value 1.
DEBUG: Error 2826: Control Line1 on dialog ConfirmInstallForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ConfirmInstallForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog ConfirmInstallForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ConfirmInstallForm, Line2, to the right
DEBUG: Error 2826: Control BannerBmp on dialog ConfirmInstallForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ConfirmInstallForm, BannerBmp, to the right
Action 13:22:54: ConfirmInstallForm. Dialog created
Action ended 13:22:55: WelcomeForm. Return value 1.
Action 13:22:55: ProgressForm.
Action start 13:22:55: ProgressForm.
DEBUG: Error 2826: Control Line1 on dialog ProgressForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ProgressForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog ProgressForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ProgressForm, Line2, to the right
DEBUG: Error 2826: Control BannerBmp on dialog ProgressForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: ProgressForm, BannerBmp, to the right
Action 13:22:55: ProgressForm. Dialog created
Action ended 13:22:55: ProgressForm. Return value 1.
Action 13:22:55: ExecuteAction.
Action start 13:22:55: ExecuteAction.
Action 13:22:55: INSTALL.
Action start 13:22:55: INSTALL.
Action 13:22:55: DIRCA_CheckFX.
Action start 13:22:55: DIRCA_CheckFX.
Action ended 13:22:55: DIRCA_CheckFX. Return value 1.
Action 13:22:55: AppSearch. Searching for installed applications
Action start 13:22:55: AppSearch.
Action ended 13:22:55: AppSearch. Return value 0.
Action 13:22:55: FindRelatedProducts. Searching for related applications
Action start 13:22:55: FindRelatedProducts.
Action ended 13:22:55: FindRelatedProducts. Return value 0.
Action 13:22:55: VSDCA_VsdLaunchConditions.
Action start 13:22:55: VSDCA_VsdLaunchConditions.
Action ended 13:22:55: VSDCA_VsdLaunchConditions. Return value 1.
Action 13:22:55: LaunchConditions. Evaluating launch conditions
Action start 13:22:55: LaunchConditions.
Action ended 13:22:55: LaunchConditions. Return value 1.
Action 13:22:55: CCPSearch. Searching for qualifying products
Action start 13:22:55: CCPSearch.
Action ended 13:22:55: CCPSearch. Return value 0.
Action 13:22:55: RMCCPSearch. Searching for qualifying products
Action start 13:22:55: RMCCPSearch.
Action ended 13:22:55: RMCCPSearch. Return value 0.
Action 13:22:55: ValidateProductID.
Action start 13:22:55: ValidateProductID.
Action ended 13:22:55: ValidateProductID. Return value 1.
Action 13:22:55: CostInitialize. Computing space requirements
Action start 13:22:55: CostInitialize.
Action ended 13:22:55: CostInitialize. Return value 1.
Action 13:22:55: FileCost. Computing space requirements
Action start 13:22:55: FileCost.
Action ended 13:22:55: FileCost. Return value 1.
Action 13:22:55: IsolateComponents.
Action start 13:22:55: IsolateComponents.
Action ended 13:22:55: IsolateComponents. Return value 1.
Action 13:22:55: CostFinalize. Computing space requirements
Action start 13:22:55: CostFinalize.
Action ended 13:22:55: CostFinalize. Return value 1.
Action 13:22:55: SetODBCFolders. Initializing ODBC directories
Action start 13:22:55: SetODBCFolders.
Action ended 13:22:55: SetODBCFolders. Return value 1.
Action 13:22:55: InstallValidate. Validating install
Action start 13:22:55: InstallValidate.
Action ended 13:22:55: InstallValidate. Return value 1.
Action 13:22:55: InstallInitialize.
Action start 13:22:55: InstallInitialize.
Action ended 13:22:55: InstallInitialize. Return value 1.
Action 13:22:55: RemoveExistingProducts. Removing applications
Action start 13:22:55: RemoveExistingProducts.
Action ended 13:22:55: RemoveExistingProducts. Return value 1.
Action 13:22:55: AllocateRegistrySpace. Allocating registry space
Action start 13:22:55: AllocateRegistrySpace.
Action ended 13:22:55: AllocateRegistrySpace. Return value 1.
Action 13:22:55: ProcessComponents. Updating component registration
Action start 13:22:55: ProcessComponents.
Action 13:22:55: GenerateScript. Generating script operations for action:
GenerateScript: Updating component registration
Action ended 13:22:56: ProcessComponents. Return value 1.
Action 13:22:56: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:22:56: MsiUnpublishAssemblies.
Action ended 13:22:56: MsiUnpublishAssemblies. Return value 1.
Action 13:22:56: UnpublishComponents. Unpublishing Qualified Components
Action start 13:22:56: UnpublishComponents.
Action ended 13:22:56: UnpublishComponents. Return value 1.
Action 13:22:56: UnpublishFeatures. Unpublishing Product Features
Action start 13:22:56: UnpublishFeatures.
Action ended 13:22:56: UnpublishFeatures. Return value 1.
Action 13:22:56: StopServices. Stopping services
Action start 13:22:56: StopServices.
Action ended 13:22:56: StopServices. Return value 1.
Action 13:22:56: DeleteServices. Deleting services
Action start 13:22:56: DeleteServices.
Action ended 13:22:56: DeleteServices. Return value 1.
Action 13:22:56: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:22:56: UnregisterComPlus.
Action ended 13:22:56: UnregisterComPlus. Return value 1.
Action 13:22:56: SelfUnregModules. Unregistering modules
Action start 13:22:56: SelfUnregModules.
Action ended 13:22:56: SelfUnregModules. Return value 1.
Action 13:22:56: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:22:56: UnregisterTypeLibraries.
Action ended 13:22:56: UnregisterTypeLibraries. Return value 1.
Action 13:22:56: RemoveODBC. Removing ODBC components
Action start 13:22:56: RemoveODBC.
RemoveODBC:
Action ended 13:22:56: RemoveODBC. Return value 1.
Action 13:22:56: UnregisterFonts. Unregistering fonts
Action start 13:22:56: UnregisterFonts.
Action ended 13:22:56: UnregisterFonts. Return value 1.
Action 13:22:56: RemoveRegistryValues. Removing system registry values
Action start 13:22:56: RemoveRegistryValues.
Action ended 13:22:56: RemoveRegistryValues. Return value 1.
Action 13:22:56: UnregisterClassInfo. Unregister Class servers
Action start 13:22:56: UnregisterClassInfo.
Action ended 13:22:56: UnregisterClassInfo. Return value 1.
Action 13:22:56: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:22:56: UnregisterExtensionInfo.
Action ended 13:22:56: UnregisterExtensionInfo. Return value 1.
Action 13:22:56: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:22:56: UnregisterProgIdInfo.
Action ended 13:22:56: UnregisterProgIdInfo. Return value 1.
Action 13:22:56: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:22:56: UnregisterMIMEInfo.
Action ended 13:22:56: UnregisterMIMEInfo. Return value 1.
Action 13:22:56: RemoveIniValues. Removing INI files entries
Action start 13:22:56: RemoveIniValues.
Action ended 13:22:56: RemoveIniValues. Return value 1.
Action 13:22:56: RemoveShortcuts. Removing shortcuts
Action start 13:22:56: RemoveShortcuts.
Action ended 13:22:56: RemoveShortcuts. Return value 1.
Action 13:22:56: RemoveEnvironmentStrings. Updating environment strings
Action start 13:22:56: RemoveEnvironmentStrings.
Action ended 13:22:56: RemoveEnvironmentStrings. Return value 1.
Action 13:22:56: RemoveDuplicateFiles. Removing duplicated files
Action start 13:22:56: RemoveDuplicateFiles.
Action ended 13:22:56: RemoveDuplicateFiles. Return value 1.
Action 13:22:56: RemoveFiles. Removing files
Action start 13:22:56: RemoveFiles.
Action ended 13:22:56: RemoveFiles. Return value 1.
Action 13:22:56: RemoveFolders. Removing folders
Action start 13:22:56: RemoveFolders.
Action ended 13:22:56: RemoveFolders. Return value 1.
Action 13:22:56: CreateFolders. Creating folders
Action start 13:22:56: CreateFolders.
CreateFolders: Folder: Creating folders
Action ended 13:22:56: CreateFolders. Return value 1.
Action 13:22:56: MoveFiles. Moving files
Action start 13:22:56: MoveFiles.
Action ended 13:22:56: MoveFiles. Return value 1.
Action 13:22:56: InstallFiles. Copying new files
Action start 13:22:56: InstallFiles.
InstallFiles: File: Copying new files, Directory: , Size:
Action ended 13:22:56: InstallFiles. Return value 1.
Action 13:22:56: PatchFiles. Patching files
Action start 13:22:56: PatchFiles.
Action ended 13:22:56: PatchFiles. Return value 1.
Action 13:22:56: DuplicateFiles. Creating duplicate files
Action start 13:22:56: DuplicateFiles.
Action ended 13:22:56: DuplicateFiles. Return value 1.
Action 13:22:56: BindImage. Binding executables
Action start 13:22:56: BindImage.
Action ended 13:22:56: BindImage. Return value 1.
Action 13:22:56: CreateShortcuts. Creating shortcuts
Action start 13:22:56: CreateShortcuts.
CreateShortcuts: Shortcut: Creating shortcuts
Action ended 13:22:56: CreateShortcuts. Return value 1.
Action 13:22:56: RegisterClassInfo. Registering Class servers
Action start 13:22:56: RegisterClassInfo.
Action ended 13:22:56: RegisterClassInfo. Return value 1.
Action 13:22:56: RegisterExtensionInfo. Registering extension servers
Action start 13:22:56: RegisterExtensionInfo.
Action ended 13:22:56: RegisterExtensionInfo. Return value 1.
Action 13:22:56: RegisterProgIdInfo. Registering program identifiers
Action start 13:22:56: RegisterProgIdInfo.
Action ended 13:22:56: RegisterProgIdInfo. Return value 1.
Action 13:22:56: RegisterMIMEInfo. Registering MIME info
Action start 13:22:56: RegisterMIMEInfo.
Action ended 13:22:56: RegisterMIMEInfo. Return value 1.
Action 13:22:56: WriteRegistryValues. Writing system registry values
Action start 13:22:56: WriteRegistryValues.
Action ended 13:22:56: WriteRegistryValues. Return value 1.
Action 13:22:56: WriteIniValues. Writing INI files values
Action start 13:22:56: WriteIniValues.
Action ended 13:22:56: WriteIniValues. Return value 1.
Action 13:22:56: WriteEnvironmentStrings. Updating environment strings
Action start 13:22:56: WriteEnvironmentStrings.
Action ended 13:22:56: WriteEnvironmentStrings. Return value 1.
Action 13:22:56: RegisterFonts. Registering fonts
Action start 13:22:56: RegisterFonts.
Action ended 13:22:56: RegisterFonts. Return value 1.
Action 13:22:56: InstallODBC. Installing ODBC components
Action start 13:22:56: InstallODBC.
Action ended 13:22:56: InstallODBC. Return value 0.
Action 13:22:56: RegisterTypeLibraries. Registering type libraries
Action start 13:22:56: RegisterTypeLibraries.
Action ended 13:22:56: RegisterTypeLibraries. Return value 1.
Action 13:22:56: SelfRegModules. Registering modules
Action start 13:22:56: SelfRegModules.
Action ended 13:22:56: SelfRegModules. Return value 1.
Action 13:22:56: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:22:56: RegisterComPlus.
Action ended 13:22:56: RegisterComPlus. Return value 1.
Action 13:22:56: InstallServices. Installing new services
Action start 13:22:56: InstallServices.
Action ended 13:22:56: InstallServices. Return value 1.
Action 13:22:56: StartServices. Starting services
Action start 13:22:56: StartServices.
Action ended 13:22:56: StartServices. Return value 1.
Action 13:22:56: _C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install.SetProperty.
Action start 13:22:56: _C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install.SetProperty.
Action ended 13:22:56: _C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install.SetProperty. Return value 1.
_C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install:
Action ended 13:22:56: _C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install. Return value 1.
Action 13:22:56: RegisterUser. Registering user
Action start 13:22:56: RegisterUser.
Action ended 13:22:56: RegisterUser. Return value 1.
Action 13:22:56: RegisterProduct. Registering product
Action start 13:22:56: RegisterProduct.
RegisterProduct: Registering product
Action ended 13:22:56: RegisterProduct. Return value 1.
Action 13:22:56: PublishComponents. Publishing Qualified Components
Action start 13:22:56: PublishComponents.
Action ended 13:22:56: PublishComponents. Return value 1.
Action 13:22:56: MsiPublishAssemblies. Publishing assembly information
Action start 13:22:56: MsiPublishAssemblies.
MsiPublishAssemblies: Application Context:Publishing assembly information, Assembly Name:
Action ended 13:22:56: MsiPublishAssemblies. Return value 1.
Action 13:22:56: PublishFeatures. Publishing Product Features
Action start 13:22:56: PublishFeatures.
PublishFeatures: Feature: Publishing Product Features
Action ended 13:22:56: PublishFeatures. Return value 1.
Action 13:22:56: PublishProduct. Publishing product information
Action start 13:22:56: PublishProduct.
PublishProduct:
Action ended 13:22:56: PublishProduct. Return value 1.
Action 13:22:56: InstallFinalize.
Action start 13:22:56: InstallFinalize.
Action 13:22:56: ProcessComponents. Updating component registration
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {88153594-9E38-D4C4-1515-B11FBB062B3C} 3: C:\Program Files\VisualCron 3\OpenSmtp.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {CEA64037-F58E-6E1D-7C73-B118D1FCE740} 3: C:\Program Files\VisualCron 3\lang\lang61_spa.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {B7710EC4-05E6-0A96-C836-C8A5ECD2F6B0} 3: C:\Program Files\VisualCron 3\sounds\reminder2.wav
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {3999C737-4516-16AB-8E04-18443D9E234F} 3: C:\Program Files\VisualCron 3\lang\lang58_rus.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {CA04C265-174B-FC22-B08B-6611B718822B} 3: C:\Program Files\VisualCron 3\lang\lang10_dut.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {DBCCEF1D-E1B5-8743-3392-B289F2B642EE} 3: C:\Program Files\VisualCron 3\lang\lang57_cze.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {CBD7289C-962D-B19E-027F-17C88A605F3F} 3: C:\Program Files\VisualCron 3\Infragistics2.Win.UltraWinToolbars.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {D50F639D-A689-48C3-735E-048DDBD050C0} 3: C:\Program Files\VisualCron 3\lang\lang4_bul.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {0F7DBA51-74F3-E22B-6808-7A80F48E219B} 3: C:\Program Files\VisualCron 3\doc\license.rtf
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {3C26D3AD-71F6-C884-1FC8-412FCC23BF0A} 3: C:\Program Files\VisualCron 3\Infragistics2.Win.UltraWinEditors.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {B72427BE-DF1B-010D-EAC7-20539C901147} 3: C:\Program Files\VisualCron 3\data\ExitCodes.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {DB509693-0F99-80BA-E0C5-134A196A70C1} 3: C:\Program Files\VisualCron 3\Infragistics2.Win.UltraWinTabControl.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {D97ABC37-3F6F-CCB9-A07D-3EBF1F648B21} 3: C:\Program Files\VisualCron 3\doc\VisualCron3.pdf
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {F3B5B7EC-363D-9A96-D755-F15AE3DB2464} 3: C:\Program Files\VisualCron 3\lang\lang34_pol.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {C60FB16D-26BC-AE5B-C16F-D7727F9741C2} 3: C:\Program Files\VisualCron 3\Infragistics2.Excel.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {EA6128BB-6084-D3E2-28F7-50410952B2AB} 3: C:\Program Files\VisualCron 3\lang\lang59_nor.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {24A25062-2E55-EAC0-561B-460ED4F2ABD6} 3: C:\Program Files\VisualCron 3\lang\lang54_dan.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {87CF7C23-5450-832E-9851-F229A49B95DF} 3: C:\Program Files\VisualCron 3\VisualCronService_nat.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {666E4C88-D815-3DDA-D2F2-5CE298585BF3} 3: C:\Program Files\VisualCron 3\Infragistics2.Win.UltraWinStatusBar.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {690C27CC-7557-15F3-C4EC-52271FC96F9F} 3: C:\Program Files\VisualCron 3\doc\VisualCron3.rtf
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {DAC096E2-CCBA-A8F3-3FEA-D156C3ABD807} 3: C:\Program Files\VisualCron 3\lang\lang18_ger.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {A9BCB6CE-E6BC-B79F-E8C1-90658024ED59} 3: C:\Program Files\VisualCron 3\Babel.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {D0C024A3-5D5F-3E5E-A09E-7CD2C72CD256} 3: C:\Program Files\VisualCron 3\lang\lang16_fre.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {1D775B62-6DC3-D958-33BA-8CC08C292FF2} 3: C:\Program Files\VisualCron 3\Infragistics2.Shared.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {F1D461C8-EEB5-670F-3D79-B96009B7F4C1} 3: C:\Program Files\VisualCron 3\Infragistics2.Win.Misc.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {3E01D35D-F45B-D02C-51CB-9F3D0A1B71D8} 3: C:\Program Files\VisualCron 3\lang\lang62_fil.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {2DC25F3A-488E-BB9F-E235-CEFF555D8B90} 3: C:\Program Files\VisualCron 3\lang\lang9_cro.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {2C8DAF0C-CB9D-F9FD-D5E7-17D30554F5AC} 3: C:\Program Files\VisualCron 3\lang\lang22_hun.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {24BD66EE-A93F-701F-F975-F040055634A8} 3: C:\Program Files\VisualCron 3\sounds\reminder1.wav
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {086012FC-98AB-DAF4-0897-0086B05E725C} 3: C:\Program Files\VisualCron 3\img\visualcron.ico
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {1A054926-68C2-0B12-2018-A6B566A2DC5F} 3: C:\Program Files\VisualCron 3\lang\lang55_por.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {B994FDF4-7D89-EE0D-9B19-EAF942B911D8} 3: C:\Program Files\VisualCron 3\img\pdf.ico
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {27A16753-41EF-87BD-8A96-E20C1D7A53F7} 3: C:\Program Files\VisualCron 3\lang\lang60_far.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {4BDF68BA-1A2A-84A1-1235-C933AC5A89B5} 3: C:\Program Files\VisualCron 3\lang\lang25_ita.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {8DF32951-E0D3-AFB6-F7F6-D2634D12CAD9} 3: C:\Program Files\VisualCron 3\Infragistics2.Win.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {AE009528-216A-26F7-F5DE-566C952292D5} 3: C:\Program Files\VisualCron 3\Infragistics2.Win.UltraWinGrid.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {A15E9FC5-D0A4-BDB8-9CA4-F1A6DE3CB6C8} 3: C:\Program Files\VisualCron 3\lang\lang11_eng.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {2D594033-3B4D-C292-38BB-9B219190A710} 3: C:\Program Files\VisualCron 3\Infragistics2.Win.UltraWinGrid.ExcelExport.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {2033235A-C4F9-3FB4-549F-270556E6F0C9} 3: C:\Program Files\VisualCron 3\lang\lang36_rom.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {BAD27D19-2E07-7B02-368C-01790CC23BFB} 3: C:\Program Files\VisualCron 3\sounds\reminder3.wav
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {905E0FAF-AF33-6659-F5AD-844CEA840336} 3: C:\Program Files\VisualCron 3\Infragistics2.Win.UltraWinTree.v6.1.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {E7424FF9-BF4E-9F49-974C-BBE46322A305} 3: C:\Program Files\VisualCron 3\lang\lang35_por.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {2A56DDF9-2676-796D-FE32-C902BF41E57A} 3: C:\Program Files\VisualCron 3\lang\lang33_nor.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {2CA9D3D9-8447-0115-BAF5-64819D810104} 3: C:\Program Files\VisualCron 3\Definitions.dll
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {800316F4-2637-679A-CE30-978D2145ACA4} 3: C:\Program Files\VisualCron 3\lang\lang42_swe.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {C78E7C1F-5455-9F37-2F75-65926A964BF8} 3: C:\Program Files\VisualCron 3\lang\lang19_gre.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {9D4B12D7-66BC-0E45-9686-82CBB739D485} 3: C:\Program Files\VisualCron 3\lang\lang21_hin.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {903359BB-5F5B-15A8-A2F0-0A13CD4C45A7} 3: C:\Program Files\VisualCron 3\lang\lang14_far.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {584F4E84-8D3F-A54B-9CAC-0EC4F64CA22A} 3: C:\Program Files\VisualCron 3\cert\makecert.exe
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {9627B82E-5D52-574A-8773-A63F63F13DCC} 3: C:\Program Files\VisualCron 3\lang\lang56_spa.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {907F52E5-CC46-8DC3-8ED4-046648F7EDF1} 3: C:\Program Files\VisualCron 3\lang\vc_lang.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {223F2388-A695-A752-32D1-EC7B7D0062BB} 3: C:\Program Files\VisualCron 3\lang\lang15_fin.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {7514AE61-D0BC-3F40-0CE1-9CF28A41F17F} 3: C:\Program Files\VisualCron 3\lang\lang7_cat.xml
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 3: C:\Program Files\VisualCron 3\
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {48A96CAA-4931-3C9B-CF0A-346925063CD2} 3: C:\Program Files\VisualCron 3\cert\
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {3580B2C5-C708-3063-5541-5A692C0853AC} 3: C:\Program Files\VisualCron 3\settings\
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {948AE2A3-1088-3E72-2017-3C8C965C3D9A} 3: C:\Program Files\VisualCron 3\lang\
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {2F62ECC7-A5CD-D065-7517-C0305FEA0819} 3: C:\Program Files\VisualCron 3\log\
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {7E08411A-8C3E-4C12-EAA2-B459EF3C389D} 3: C:\Program Files\VisualCron 3\VisualCronClient.exe
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {D2C86322-C580-847A-6D92-91DF1EA24A77} 3: C:\Program Files\VisualCron 3\VisualCronService.exe.config
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {B0B3A3E7-8D2D-DA11-9A95-9AD4ED842520} 3: C:\Program Files\VisualCron 3\VisualCronService.exe
1: {5076C80B-9790-4C99-9C07-9C0230B30FB7} 2: {79499184-5D2A-13EA-F8DB-7876C8C5235B} 3: C:\Program Files\VisualCron 3\VisualCronClient.exe.config
CreateFolders: Folder: C:\Program Files\VisualCron 3\lang\
CreateFolders: Folder: C:\Program Files\VisualCron 3\cert\
CreateFolders: Folder: C:\Program Files\VisualCron 3\settings\
CreateFolders: Folder: C:\Program Files\VisualCron 3\log\
InstallFiles: File: OpenSmtp.dll, Directory: C:\Program Files\VisualCron 3\, Size: 45056
InstallFiles: File: lang61_spa.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 1014
InstallFiles: File: reminder2.wav, Directory: C:\Program Files\VisualCron 3\sounds\, Size: 27734
InstallFiles: File: lang58_rus.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 30730
InstallFiles: File: lang10_dut.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 85368
InstallFiles: File: lang57_cze.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 41124
InstallFiles: File: Infragistics2.Win.UltraWinToolbars.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 1323008
InstallFiles: File: lang4_bul.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 66836
InstallFiles: File: license.rtf, Directory: C:\Program Files\VisualCron 3\doc\, Size: 13993
InstallFiles: File: Infragistics2.Win.UltraWinEditors.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 397312
InstallFiles: File: ExitCodes.xml, Directory: C:\Program Files\VisualCron 3\data\, Size: 249517
InstallFiles: File: Infragistics2.Win.UltraWinTabControl.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 225280
InstallFiles: File: VisualCron3.pdf, Directory: C:\Program Files\VisualCron 3\doc\, Size: 866848
InstallFiles: File: lang34_pol.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 33396
InstallFiles: File: VisualCronClient.exe.config, Directory: C:\Program Files\VisualCron 3\, Size: 403
InstallFiles: File: Infragistics2.Excel.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 102400
InstallFiles: File: lang59_nor.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 92320
InstallFiles: File: lang54_dan.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 30950
InstallFiles: File: VisualCronService_nat.dll, Directory: C:\Program Files\VisualCron 3\, Size: 64503
InstallFiles: File: Infragistics2.Win.UltraWinStatusBar.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 180224
InstallFiles: File: VisualCron3.rtf, Directory: C:\Program Files\VisualCron 3\doc\, Size: 364652
InstallFiles: File: lang18_ger.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 66762
InstallFiles: File: Babel.dll, Directory: C:\Program Files\VisualCron 3\, Size: 32768
InstallFiles: File: lang16_fre.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 89290
InstallFiles: File: Infragistics2.Shared.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 237568
InstallFiles: File: Infragistics2.Win.Misc.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 413696
InstallFiles: File: lang62_fil.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 4106
InstallFiles: File: lang9_cro.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 32331
InstallFiles: File: lang22_hun.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 66782
InstallFiles: File: reminder1.wav, Directory: C:\Program Files\VisualCron 3\sounds\, Size: 25816
InstallFiles: File: visualcron.ico, Directory: C:\Program Files\VisualCron 3\img\, Size: 26694
InstallFiles: File: lang55_por.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 32674
InstallFiles: File: pdf.ico, Directory: C:\Program Files\VisualCron 3\img\, Size: 766
InstallFiles: File: lang60_far.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 63062
InstallFiles: File: lang25_ita.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 90296
InstallFiles: File: Infragistics2.Win.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 2043904
InstallFiles: File: Infragistics2.Win.UltraWinGrid.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 1835008
InstallFiles: File: lang11_eng.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 105032
InstallFiles: File: Infragistics2.Win.UltraWinGrid.ExcelExport.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 65536
InstallFiles: File: lang36_rom.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 83098
InstallFiles: File: reminder3.wav, Directory: C:\Program Files\VisualCron 3\sounds\, Size: 15806
InstallFiles: File: Infragistics2.Win.UltraWinTree.v6.1.dll, Directory: C:\Program Files\VisualCron 3\, Size: 565248
InstallFiles: File: lang35_por.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 47904
InstallFiles: File: lang33_nor.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 31530
InstallFiles: File: Definitions.dll, Directory: C:\Program Files\VisualCron 3\, Size: 90112
InstallFiles: File: lang42_swe.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 94016
InstallFiles: File: VisualCronService.exe, Directory: C:\Program Files\VisualCron 3\, Size: 356352
InstallFiles: File: lang19_gre.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 90100
InstallFiles: File: VisualCronClient.exe, Directory: C:\Program Files\VisualCron 3\, Size: 1832444
InstallFiles: File: VisualCronService.exe.config, Directory: C:\Program Files\VisualCron 3\, Size: 2036
InstallFiles: File: lang21_hin.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 64130
InstallFiles: File: lang14_far.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 31488
InstallFiles: File: makecert.exe, Directory: C:\Program Files\VisualCron 3\cert\, Size: 39936
InstallFiles: File: lang56_spa.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 65238
InstallFiles: File: vc_lang.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 6976
InstallFiles: File: lang15_fin.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 42098
InstallFiles: File: lang7_cat.xml, Directory: C:\Program Files\VisualCron 3\lang\, Size: 58438
CreateShortcuts: Shortcut: VISUAL~2|VisualCron 3
CreateShortcuts: Shortcut: DOCUME~1|Documentation
CreateShortcuts: Shortcut: VISUAL~3|VisualCron 3
DEBUG: Error 2835: The control ErrorIcon was not found on dialog ErrorDialog
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2835. The arguments are: ErrorIcon, ErrorDialog,
Error 1001. Unknown error "-1".
MSI (s) (14!20) [13:22:59:562]:
DEBUG: Error 2769: Custom Action _C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install did not close 1 MSIHANDLEs.
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2769. The arguments are: _C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install, 1,
Action ended 13:22:59: InstallFinalize. Return value 3.
Action 13:22:59: Rollback. Rolling back action:
Rollback: _C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install
Rollback: Creating shortcuts
Rollback: Copying new files
Info 1903. Scheduling reboot operation: Deleting file C:\Program Files\VisualCron 3\TBD2A.tmp. Must reboot to complete operation.
Info 1903. Scheduling reboot operation: Deleting file C:\Program Files\VisualCron 3\TBD2B.tmp. Must reboot to complete operation.
Rollback: Creating folders
Rollback: Removing ODBC components
Rollback: Updating component registration
Action ended 13:22:59: INSTALL. Return value 3.
Property(S): UpgradeCode = {54A37E82-E9E7-49F0-A0DF-B737435CBEB8}
Property(S): _C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install = /installtype=notransaction /action=install /LogFile= "C:\Program Files\VisualCron 3\VisualCronService.exe" "C:\DOCUME~1\p55484\LOCALS~1\Temp\CFG5.tmp"
Property(S): TARGETDIR = C:\Program Files\VisualCron 3\
Property(S): _A96BAA9A427A4453A0D9D4D6003A97DF = C:\Program Files\VisualCron 3\lang\
Property(S): _B8EBC8305AD343C387584233BD3B96AE = C:\Program Files\VisualCron 3\sounds\
Property(S): _1242E194105041A284495867D732B524 = C:\Program Files\VisualCron 3\doc\
Property(S): _012431D7CA654ED99D868AD015D3014C = C:\Program Files\VisualCron 3\data\
Property(S): _CB11A439DEF44F599B9903B449653763 = C:\Program Files\VisualCron 3\img\
Property(S): _1FBF09F056144543965CD0EE4B492726 = C:\Program Files\VisualCron 3\cert\
Property(S): DesktopFolder = C:\Documents and Settings\All Users\Desktop\
Property(S): ProgramMenuFolder = C:\Documents and Settings\All Users\Start Menu\Programs\
Property(S): _83C0159625294E9FBE999BD82F7C983A = C:\Documents and Settings\All Users\Start Menu\Programs\VisualCron 3\
Property(S): SourceDir = C:\
Property(S): _A6F417EDD3FA48F0A32F9DB49CABDAEE = C:\Program Files\VisualCron 3\settings\
Property(S): _AE985C2921A546E1BEA4EBB2DA17D107 = C:\Program Files\VisualCron 3\log\
Property(S): VSDFXAvailable = TRUE
Property(S): VSDFrameworkVersion = 2.0.50727
Property(S): VSDAllowLaterFrameworkVersions = False
Property(S): ProductName = VisualCron 3.2.6
Property(S): ProductCode = {5076C80B-9790-4C99-9C07-9C0230B30FB7}
Property(S): ProductVersion = 3.2.6
Property(S): Manufacturer = neteject.com
Property(S): ARPHELPLINK = http://www.visualcron.com
Property(S): ARPCONTACT = neteject.com
Property(S): ARPCOMMENTS = The real task scheduler alternative
Property(S): ARPURLINFOABOUT = http://www.visualcron.com
Property(S): ProductLanguage = 0
Property(S): ALLUSERS = 1
Property(S): ARPPRODUCTICON = _6FEFF9B68218417F98F549.exe
Property(S): SecureCustomProperties = PREVIOUSVERSIONSINSTALLED;NEWERPRODUCTFOUND
Property(S): RedirectedDllSupport = 2
Property(S): VersionNT = 502
Property(S): VSDNETURLMSG = This setup requires the .NET Framework version 2.0.50727. Please install the .NET Framework and run this setup again. The .NET Framework can be obtained from the web. Would you like to do this now?
Property(S): VSDIISMSG = This setup requires Internet Information Server 4.0 or higher and Windows NT 4.0, Windows 2000 or higher. This setup cannot be installed on Windows 95, Windows 98, or Windows Me. Please install Internet Information Server and run this setup again.
Property(S): VSDUIANDADVERTISED = This advertised application will not be installed because it might be unsafe. Contact your administrator to change the installation user interface option of the package to basic.
Property(S): VSDNETMSG = This setup requires the .NET Framework version 2.0.50727. Please install the .NET Framework and run this setup again.
Property(S): VSDINVALIDURLMSG = The specified path '[2]' is unavailable. The Internet Information Server might not be running or the path exists and is redirected to another machine. Please check the status of this virtual directory in the Internet Services Manager.
Property(S): VSDVERSIONMSG = Unable to install because a newer version of this product is already installed.
Property(S): MaintenanceForm_Action = Repair
Property(S): ErrorDialog = ErrorDialog
Property(S): SFF_UpFldrBtn = UpFldrBtn
Property(S): SFF_NewFldrBtn = NewFldrBtn
Property(S): FolderForm_AllUsers = ME
Property(S): FolderForm_AllUsersVisible = 1
Property(S): EulaForm_Property = No
Property(S): AdminEulaForm_Property = No
Property(S): AdminMaintenanceForm_Action = Repair
Property(S): DefaultUIFont = VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400
Property(S): WelcomeForm_NextArgs = EulaForm
Property(S): EulaForm_PrevArgs = WelcomeForm
Property(S): EulaForm_NextArgs = FolderForm
Property(S): FolderForm_PrevArgs = EulaForm
Property(S): FolderForm_NextArgs = ConfirmInstallForm
Property(S): ConfirmInstallForm_PrevArgs = FolderForm
Property(S): AdminWelcomeForm_NextArgs = AdminEulaForm
Property(S): AdminEulaForm_PrevArgs = AdminWelcomeForm
Property(S): AdminEulaForm_NextArgs = AdminFolderForm
Property(S): AdminFolderForm_PrevArgs = AdminEulaForm
Property(S): AdminFolderForm_NextArgs = AdminConfirmInstallForm
Property(S): AdminConfirmInstallForm_PrevArgs = AdminFolderForm
Property(S): PackageCode = {2D78A4C6-D8A9-4BD3-91C0-FDE7BA2DF5DC}
Property(S): ProductState = -1
Property(S): PackagecodeChanging = 1
Property(S): CURRENTDIRECTORY = C:\
Property(S): CLIENTUILEVEL = 0
Property(S): CLIENTPROCESSID = 7664
Property(S): USERNAME = ITI
Property(S): COMPANYNAME = GDC4S
Property(S): VersionDatabase = 200
Property(S): ACTION = INSTALL
Property(S): EXECUTEACTION = INSTALL
Property(S): ROOTDRIVE = G:\
Property(S): INSTALLLEVEL = 1
Property(S): SECONDSEQUENCE = 1
Property(S): ADDLOCAL = DefaultFeature
Property(S): VersionMsi = 3.01
Property(S): WindowsBuild = 3790
Property(S): ServicePackLevel = 1
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 3
Property(S): WindowsFolder = C:\WINDOWS\
Property(S): WindowsVolume = C:\
Property(S): SystemFolder = C:\WINDOWS\system32\
Property(S): System16Folder = C:\WINDOWS\system\
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\DOCUME~1\p55484\LOCALS~1\Temp\
Property(S): ProgramFilesFolder = C:\Program Files\
Property(S): CommonFilesFolder = C:\Program Files\Common Files\
Property(S): AppDataFolder = C:\Documents and Settings\p55484\Application Data\
Property(S): FavoritesFolder = C:\Documents and Settings\p55484\Favorites\
Property(S): NetHoodFolder = C:\Documents and Settings\p55484\NetHood\
Property(S): PersonalFolder = C:\Documents and Settings\p55484\My Documents\
Property(S): PrintHoodFolder = C:\Documents and Settings\p55484\PrintHood\
Property(S): RecentFolder = C:\Documents and Settings\p55484\Recent\
Property(S): SendToFolder = C:\Documents and Settings\p55484\SendTo\
Property(S): TemplateFolder = C:\Documents and Settings\All Users\Templates\
Property(S): CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(S): LocalAppDataFolder = C:\Documents and Settings\p55484\Local Settings\Application Data\
Property(S): MyPicturesFolder = C:\Documents and Settings\p55484\My Documents\My Pictures\
Property(S): AdminToolsFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Property(S): StartMenuFolder = C:\Documents and Settings\All Users\Start Menu\
Property(S): FontsFolder = C:\WINDOWS\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): Intel = 15
Property(S): PhysicalMemory = 4095
Property(S): VirtualMemory = 7090
Property(S): AdminUser = 1
Property(S): LogonUser = p55484
Property(S): UserSID = S-1-5-21-4152260629-2040456560-2917202725-1010
Property(S): UserLanguageID = 1033
Property(S): ComputerName = AZ25APP52
Property(S): SystemLanguageID = 1033
Property(S): ScreenX = 1024
Property(S): ScreenY = 768
Property(S): CaptionHeight = 19
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 13:22:59
Property(S): Date = 4/12/2006
Property(S): MsiNetAssemblySupport = 2.0.50727.42
Property(S): MsiWin32AssemblySupport = 5.2.3790.1830
Property(S): Privileged = 1
Property(S): DATABASE = C:\WINDOWS\Installer\40f1937.msi
Property(S): OriginalDatabase = C:\VisualCron.msi
Property(S): UILevel = 5
Property(S): Preselected = 1
Property(S): VSDFxConfigFile = C:\DOCUME~1\p55484\LOCALS~1\Temp\CFG5.tmp
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): SOURCEDIR = C:\
Property(S): SourcedirProduct = {5076C80B-9790-4C99-9C07-9C0230B30FB7}
Property(S): ProductToBeRegistered = 1
Action ended 13:22:59: ExecuteAction. Return value 3.
Action 13:22:59: FatalErrorForm.
Action start 13:22:59: FatalErrorForm.
DEBUG: Error 2826: Control Line1 on dialog FatalErrorForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FatalErrorForm, Line1, to the right
DEBUG: Error 2826: Control Line2 on dialog FatalErrorForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FatalErrorForm, Line2, to the right
DEBUG: Error 2826: Control BannerBmp on dialog FatalErrorForm extends beyond the boundaries of the dialog to the right by 3 pixels
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2826. The arguments are: FatalErrorForm, BannerBmp, to the right
Action 13:22:59: FatalErrorForm. Dialog created
Action ended 13:23:00: FatalErrorForm. Return value 1.
Action ended 13:23:00: INSTALL. Return value 3.
Property©: UpgradeCode = {54A37E82-E9E7-49F0-A0DF-B737435CBEB8}
Property©: TARGETDIR = C:\Program Files\VisualCron 3\
Property©: _A96BAA9A427A4453A0D9D4D6003A97DF = C:\Program Files\VisualCron 3\lang\
Property©: _B8EBC8305AD343C387584233BD3B96AE = C:\Program Files\VisualCron 3\sounds\
Property©: _1242E194105041A284495867D732B524 = C:\Program Files\VisualCron 3\doc\
Property©: _012431D7CA654ED99D868AD015D3014C = C:\Program Files\VisualCron 3\data\
Property©: _CB11A439DEF44F599B9903B449653763 = C:\Program Files\VisualCron 3\img\
Property©: _1FBF09F056144543965CD0EE4B492726 = C:\Program Files\VisualCron 3\cert\
Property©: DesktopFolder = C:\Documents and Settings\All Users\Desktop\
Property©: ProgramMenuFolder = C:\Documents and Settings\All Users\Start Menu\Programs\
Property©: _83C0159625294E9FBE999BD82F7C983A = C:\Documents and Settings\All Users\Start Menu\Programs\VisualCron 3\
Property©: SourceDir = C:\
Property©: _A6F417EDD3FA48F0A32F9DB49CABDAEE = C:\Program Files\VisualCron 3\settings\
Property©: _AE985C2921A546E1BEA4EBB2DA17D107 = C:\Program Files\VisualCron 3\log\
Property©: VSDFXAvailable = TRUE
Property©: VSDFrameworkVersion = 2.0.50727
Property©: VSDAllowLaterFrameworkVersions = False
Property©: ProductName = VisualCron 3.2.6
Property©: ProductCode = {5076C80B-9790-4C99-9C07-9C0230B30FB7}
Property©: ProductVersion = 3.2.6
Property©: Manufacturer = neteject.com
Property©: ARPHELPLINK = http://www.visualcron.com
Property©: ARPCONTACT = neteject.com
Property©: ARPCOMMENTS = The real task scheduler alternative
Property©: ARPURLINFOABOUT = http://www.visualcron.com
Property©: ProductLanguage = 0
Property©: ALLUSERS = 2
Property©: ARPPRODUCTICON = _6FEFF9B68218417F98F549.exe
Property©: SecureCustomProperties = PREVIOUSVERSIONSINSTALLED;NEWERPRODUCTFOUND
Property©: RedirectedDllSupport = 2
Property©: VersionNT = 502
Property©: VSDNETURLMSG = This setup requires the .NET Framework version 2.0.50727. Please install the .NET Framework and run this setup again. The .NET Framework can be obtained from the web. Would you like to do this now?
Property©: VSDIISMSG = This setup requires Internet Information Server 4.0 or higher and Windows NT 4.0, Windows 2000 or higher. This setup cannot be installed on Windows 95, Windows 98, or Windows Me. Please install Internet Information Server and run this setup again.
Property©: VSDUIANDADVERTISED = This advertised application will not be installed because it might be unsafe. Contact your administrator to change the installation user interface option of the package to basic.
Property©: VSDNETMSG = This setup requires the .NET Framework version 2.0.50727. Please install the .NET Framework and run this setup again.
Property©: VSDINVALIDURLMSG = The specified path '[2]' is unavailable. The Internet Information Server might not be running or the path exists and is redirected to another machine. Please check the status of this virtual directory in the Internet Services Manager.
Property©: VSDVERSIONMSG = Unable to install because a newer version of this product is already installed.
Property©: MaintenanceForm_Action = Repair
Property©: ErrorDialog = ErrorDialog
Property©: SFF_UpFldrBtn = UpFldrBtn
Property©: SFF_NewFldrBtn = NewFldrBtn
Property©: FolderForm_AllUsers = ALL
Property©: FolderForm_AllUsersVisible = 1
Property©: EulaForm_Property = Yes
Property©: AdminEulaForm_Property = No
Property©: AdminMaintenanceForm_Action = Repair
Property©: DefaultUIFont = VsdDefaultUIFont.524F4245_5254_5341_4C45_534153783400
Property©: WelcomeForm_NextArgs = EulaForm
Property©: EulaForm_PrevArgs = WelcomeForm
Property©: EulaForm_NextArgs = FolderForm
Property©: FolderForm_PrevArgs = EulaForm
Property©: FolderForm_NextArgs = ConfirmInstallForm
Property©: ConfirmInstallForm_PrevArgs = FolderForm
Property©: AdminWelcomeForm_NextArgs = AdminEulaForm
Property©: AdminEulaForm_PrevArgs = AdminWelcomeForm
Property©: AdminEulaForm_NextArgs = AdminFolderForm
Property©: AdminFolderForm_PrevArgs = AdminEulaForm
Property©: AdminFolderForm_NextArgs = AdminConfirmInstallForm
Property©: AdminConfirmInstallForm_PrevArgs = AdminFolderForm
Property©: PackageCode = {2D78A4C6-D8A9-4BD3-91C0-FDE7BA2DF5DC}
Property©: ProductState = -1
Property©: PackagecodeChanging = 1
Property©: CURRENTDIRECTORY = C:\
Property©: CLIENTUILEVEL = 0
Property©: CLIENTPROCESSID = 7664
Property©: VersionDatabase = 200
Property©: VersionMsi = 3.01
Property©: WindowsBuild = 3790
Property©: ServicePackLevel = 1
Property©: ServicePackLevelMinor = 0
Property©: MsiNTProductType = 3
Property©: WindowsFolder = C:\WINDOWS\
Property©: WindowsVolume = C:\
Property©: SystemFolder = C:\WINDOWS\system32\
Property©: System16Folder = C:\WINDOWS\system\
Property©: RemoteAdminTS = 1
Property©: TempFolder = C:\DOCUME~1\p55484\LOCALS~1\Temp\2\
Property©: ProgramFilesFolder = C:\Program Files\
Property©: CommonFilesFolder = C:\Program Files\Common Files\
Property©: AppDataFolder = C:\Documents and Settings\p55484\Application Data\
Property©: FavoritesFolder = C:\Documents and Settings\p55484\Favorites\
Property©: NetHoodFolder = C:\Documents and Settings\p55484\NetHood\
Property©: PersonalFolder = C:\Documents and Settings\p55484\My Documents\
Property©: PrintHoodFolder = C:\Documents and Settings\p55484\PrintHood\
Property©: RecentFolder = C:\Documents and Settings\p55484\Recent\
Property©: SendToFolder = C:\Documents and Settings\p55484\SendTo\
Property©: TemplateFolder = C:\Documents and Settings\All Users\Templates\
Property©: CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property©: LocalAppDataFolder = C:\Documents and Settings\p55484\Local Settings\Application Data\
Property©: MyPicturesFolder = C:\Documents and Settings\p55484\My Documents\My Pictures\
Property©: AdminToolsFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property©: StartupFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Property©: StartMenuFolder = C:\Documents and Settings\All Users\Start Menu\
Property©: FontsFolder = C:\WINDOWS\Fonts\
Property©: GPTSupport = 1
Property©: OLEAdvtSupport = 1
Property©: ShellAdvtSupport = 1
Property©: Intel = 15
Property©: PhysicalMemory = 4095
Property©: VirtualMemory = 7094
Property©: AdminUser = 1
Property©: LogonUser = p55484
Property©: UserSID = S-1-5-21-4152260629-2040456560-2917202725-1010
Property©: UserLanguageID = 1033
Property©: ComputerName = AZ25APP52
Property©: SystemLanguageID = 1033
Property©: ScreenX = 1280
Property©: ScreenY = 1024
Property©: CaptionHeight = 19
Property©: BorderTop = 1
Property©: BorderSide = 1
Property©: TextHeight = 16
Property©: ColorBits = 16
Property©: TTCSupport = 1
Property©: Time = 13:23:00
Property©: Date = 4/12/2006
Property©: MsiNetAssemblySupport = 2.0.50727.42
Property©: MsiWin32AssemblySupport = 5.2.3790.1830
Property©: Privileged = 1
Property©: USERNAME = ITI
Property©: COMPANYNAME = GDC4S
Property©: DATABASE = C:\DOCUME~1\p55484\LOCALS~1\Temp\2\40effa4.msi
Property©: OriginalDatabase = C:\VisualCron.msi
Property©: SOURCEDIR = C:\
Property©: VersionHandler = 3.01
Property©: UILevel = 5
Property©: ACTION = INSTALL
Property©: EXECUTEACTION = INSTALL
Property©: VSDFxConfigFile = C:\DOCUME~1\p55484\LOCALS~1\Temp\2\CFG2.tmp
Property©: ROOTDRIVE = G:\
Property©: CostingComplete = 1
Property©: OutOfDiskSpace = 0
Property©: OutOfNoRbDiskSpace = 0
Property©: PrimaryVolumeSpaceAvailable = 0
Property©: PrimaryVolumeSpaceRequired = 0
Property©: PrimaryVolumeSpaceRemaining = 0
Property©: INSTALLLEVEL = 1
=== Logging stopped: 4/12/2006 13:23:00 ===
MSI © (F0:28) [13:23:00:875]: Product: VisualCron 3.2.6 -- Installation failed.
MSI Install error
mrdance
, May 15 2006 09:20
Posted 15 May 2006 - 17:04
Looks like custom action _C060C58B_5886_4BDE_B76C_7759C1ECCC3E.install (probably a .NET action) fails. Only the author will be able to tell you the reason.
Do you have an appropriate version of the .NET framework installed?
Did you create this setup? If not you should contact the manufacturer.
