how to install my basic msi in a limited user
haroldxious
, Jan 26 2007 09:39
6 replies to this topic
Posted 26 January 2007 - 09:39
on my work station (win xp) i have an admin acoount and a limited user account.
as an admin, i can install and uninstall the basic msi package that ive made.
i logout then login as a limited user, i cant install and uninstall my package.
is there a way that i can install the basic msi package that ive made using a limited user account?
Posted 26 January 2007 - 17:45
Have the administrator advertise the package. Or allow the limited user to install elevated (setting the AlwaysInstallElevated policy for both the user and the machine).
Posted 29 January 2007 - 01:20
so..can i set the "allow limited user to install elevated (setting the AlwaysInstallElevated policy for both the user and the machine)." in the installer itself?
or will i set it in the registry?
is there any way that i will make an installer that can be installed in a limited user account?
im using an installshield 12.
Can i use this property in the general information product properties?
Install Condition
Condition = Privileged Message = "not installed"
Install Condition
Edited by haroldxious, 29 January 2007 - 03:41.
Posted 30 January 2007 - 09:49
| can i set the "allow limited user to install elevated (setting the AlwaysInstallElevated policy for both the user and the machine)." in the installer itself? |
No, that would defeat the purpose of this security measure.
| or will i set it in the registry? |
Either using Group Policy Editor or directly in registry.
| is there any way that i will make an installer that can be installed in a limited user account? |
Yes but it's not easy. Make sure you install the files where the user has write access, i.e. in his user profile folder. Don't write to HKEY_LOCAL_MACHINE in registry but only to HKEY_CURRENT_USER.
See also a related article in Robert Flaming's blog: UAC in MSI Notes: Should I write my installer as a Standard User install? If yes, how?
| Can i use this property in the general information product properties? |
This would prevent instalaltion if the user is not privileged (i.e. a restricted user and the packages hasn't been advertised nor has the user been elevated)
Posted 31 January 2007 - 01:58
hello stefan..thanx for ur answer..its now clear to me..
but is there any documentation about this issue? coz i need a proof on all this?
Posted 31 January 2007 - 12:30
hope you could help me...im having a hard time searching for documentations about the issue that you can ONLY install basic msi in a limited user account through group policy...
hope you could help me guys...
Posted 31 January 2007 - 16:55
Are you looking for something like this:
Installing a Package with Elevated Privileges for a Non-Admin
