There are two dll files in project.
These are also key files and marked self registered(right click on file and checked the check box "Self-register).
During uninstallation these files are not getting deleted, u may manually delete it.
How to delete it during uninstallation ?? Is it because I marked them self registered and some thing more is required to be done ... some more custom actions are required for that....
Reply soon.
self registered files are not deleted
in_install
, Mar 07 2006 15:13
Posted 07 March 2006 - 16:37
Tried following :
Shared NO
Permanent NO
COM Extract at Build Yes
On testing machine, deleted already existing entries for the files in following key:
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs"
Now, when installing and then Uninstalling removes the files....Not sure my approach is really good one. Let me know this solution is correct or not.
Shared NO
Permanent NO
Posted 07 March 2006 - 19:18
If the SharedDLL count is > 0 the files won't get removed because they are needed by another application (or the count is wrong, e.g. from a previous failed install attempt). Always test on a fresh Windows image.
Posted 08 March 2006 - 07:41
Got it..My next question is when should I mark the file SHARED YES in MSI project.
Posted 08 March 2006 - 18:22
If there's a chance that the same file might also be installed by another non-MSI setup. The Shared flag is for compatibility with legacy non-MSI setups.
