Currently I need to do a minor upgrade for our existing application, after i done it. It can perform the upgrade action but when i open the folder, the file still same and dint upgrade to the latest one. What is the problem? I am using installshield 12 to do it.
Anyone can help me?
minor upgrade (urgent)
joey ng
, Aug 20 2008 08:32
11 replies to this topic
Posted 21 August 2008 - 00:52
Thanks for your reply........
I have change the package code and the product version but still cannot.
What can i do now?
What can i do now?
Posted 21 August 2008 - 04:30
Make sure that the version of the file in minor upgrade is higher than the base file.
Posted 21 August 2008 - 08:02
Just make sure that the key file of the component that contains the file(s) to update has changed (eg. higher version for versioned files).
Posted 21 August 2008 - 09:42
Is it have any others solution to solve it except changing the file version?
Posted 21 August 2008 - 10:12
How are you installing the patch (cmd line or double clicking the msp)?
If command line is used, then use REINSTALLMODE property.
Posted 22 August 2008 - 09:30
you can do that by installing the patch with the help of batch file
Create a batch file with the following command:
msiexec /p patch.msp REINSTALL=ALL REINSTALLMODE=omus
Note: Make sure you place the patch in the same directory where the batch file is placed.
Posted 25 August 2008 - 02:25
As i know, patch is build when we know which file we need to upgrade but for my application, i dont know which file in the application need to upgrade because edit the file in the application is not i do it, i just help them build the installer and upgrade it so except create batch, is it have another method to do it?
Posted 11 September 2008 - 07:15
Finally i done it by measure the version file is higher than the existing file...
Thanks for yours help..
