Hi!
Can I configure other installed WI products (or install new products) within CA?
Anybody have experience of two installations simultaneously?
Configure other products within CA
AntonS
, Sep 27 2004 06:45
Posted 27 September 2004 - 08:23
Two MSI installations cannot be in Execute sequence at the same time. In theory you could launch another MSI from your UI sequence but I wouldn't recommend this. One reason is that it won't work if your setup runs in silent mode (no UI sequence in this case).
Posted 28 September 2004 - 09:48
It may be possible to run actions before InstallInitialize or after InstallFinalize (this starts and ends the transaction installation process). However, this is not good practice.
