Self-repair?
Posted 21 January 2002 - 18:57
Posted 21 January 2002 - 19:45
The first thing you will want to do is to enable installation logging. It will give you a surplus of information on what is happening during installs, uninstalls, and repairs. Most likely files are getting overwritten or something like that. The log will show you the way!
Put the following text into a .reg file and run it on the affected machine. This will turn on the logging
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Installer]
"Logging"="voicewarmup"
Remove this key when your done fixing your issue. It will run for anything installed using MSI. It will slow down the install drastically but the information can be well worth it. It will dump the log into your temp directory, with a file format like MSI?????.log
Kurt Schneider
