How can I detect if a user has already got MDAC on their machine - and if they do not how can I install it? Am I completely wrong in saying if I install the mdac merge module that this will install madac if it is not there??
thanks for any help -
INstalling MDAC - help!!
bernadettefearon
, Aug 07 2001 11:43
Posted 07 August 2001 - 19:17
That's exactly what you want to do - add the MDAC merge module to the package.
Posted 08 August 2001 - 16:33
If it is the MDAC module from Microsoft, all that does is check to see if MDAC is installed and then gives a message telling the user to install it before continuning.
ISWI may have a different one that actually installs MDAC, but the MS mdac.msm file checks and stops the installer if the proper version isn't installed (at least for MDAC 2.5)
