The msi is installed and unistalled properly. But the msi is not copied into [Windows Folder]\Downloaded Installations.
what settings I need to do for that.
regards,
Priya
The MSI is not copied in Downloaded Installations
epriya2003
, Jan 05 2006 17:52
Posted 05 January 2006 - 23:24
Set Cache Web Download to Yes in the release view.
Posted 08 January 2006 - 15:44
I tried this as follows:
Cache Web Download:
yes
cache Path
[WindowsFolder]Downloaded Installations
Here, I am generating exe and msi both for same project. The exe during installations copies the setup in [WindowsFolder]Downloaded Installations
but while running msi, it does not copy ??
Cache Web Download:
yes
cache Path
Posted 08 January 2006 - 23:15
Why do you need the MSI? The end user can still extract your MSI using setup.exe /a at the command line and if they do so chances are they are windows admins and don't want the file to cache locally.
Posted 10 January 2006 - 14:41
setup.exe is responsible for copying the msi file to Downloaded Instalaltions. It is mainly used for instalaltions downloaded from the web. Since the functionality is in setup.exe it doesn't happen if you don't use setup.exe.
