In my recently project I used IS to generate a *.msi file. The *.msi should have the same ProductCode with the Project setting(It always did) .
But this time it didn't. >> I used the installshield to open the *.msi files; I found that they had different product code (different to the id set in the project).
I have checked the
Installation Information >> General Information >> Product Properties >> Product Code
Behavior and Logic >> Property Manager >> ProductCode
Additional Tools >> Direct Editor >> Property >> ProdutCode
---they are the same
if I set the product code in
Media >> Releases >> Product Configuration >> Product Code
it did solved the problem but I thought it(*.msi) should default to use the same product code with project settings! even if I did not set Product Code in
Product Configuration.
If someone knows what's wrong with the project, please let me know.
Hermione Cai
