I cant see a way of putting this CA into the install dialog sequence, and then carrying on. when i put it outside the dialog sequence, (has to be after components selected) the install fails with a 'install interupted' error.
Can anyone help?
Posted 09 February 2001 - 18:16
Can anyone help?
Posted 09 February 2001 - 18:40
Check the return value of your CA, or set it to "ignore return value". Looks like your CA returns a value that the Installer interprets as abort. CA return values are documented in MSI Help.
Posted 09 February 2001 - 19:13
Posted 09 February 2001 - 20:57
Regards,
Jeff Day
