Hello!
I performed a search about this with no luck.
Is there a way to retrieve a launched application's return code (executed via launchappandwait)?
Thanks!
Dave
Retrieving launched application's return code
rideSD
, Nov 29 2005 02:18
Posted 30 November 2005 - 09:22
In InstallShield Professional 6 you should use the extended version of LaunchAppAndWait (LaunchAppEx) which can be found here:
http://www.installsi.../en/isp_ext.htm
Later versions of IS Professional have an enhanced version of LaunchAppAndWait built in with similar functionality.
