Hi All,
I have an application having a windows service. When I try to remove the app, ocassionally the uninstall process stalls completely. Only a hard reboot kills the uninstall.
After the reboot, if I manually stop the service, the uninstall works perfect.
Looking at the logs InstallValidate seems to be dying.
---snip from log----
Action start 11:56:44: InstallValidate.
MSI (s) (94:F4) [11:56:44:414]: Note: 1: 2262 2: RemoveFile 3: -2147287038
MSI (s) (94:F4) [11:56:44:414]: Note: 1: 2262 2: DuplicateFile 3: -2147287038
MSI (s) (94:F4) [11:56:44:414]: Note: 1: 2262 2: ReserveCost 3: -2147287038
MSI (s) (94:F4) [11:56:44:414]: Note: 1: 2205 2: 3: _RemoveFilePath
MSI (s) (94:F4) [11:56:47:004]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (94:F4) [11:56:47:004]: Note: 1: 2262 2: BindImage 3: -2147287038
MSI (s) (94:F4) [11:56:47:004]: Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (s) (94:F4) [11:56:47:004]: Note: 1: 2262 2: SelfReg 3: -2147287038
MSI (s) (94:F4) [11:56:47:004]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (94:F4) [11:56:47:004]: Note: 1: 2262 2: Font 3: -2147287038
MSI (s) (94:F4) [11:56:47:004]: Note: 1: 2727 2:
In cases where the uninstallation went thru, the above log lines are followed by the list of files held by the service.
With all the above data, it seems that the service is holding up some file handles and InstallValidate is trying to enumerate the same... [JUST A GUESS] Not sure whats happening exactly.
Any pointers??
Thanks for your help.
Regards,
Amit
Uninstall hang
amitsgupte
, Apr 17 2007 11:59
Posted 18 April 2007 - 15:52
Did you generate the log with the ! option?
Posted 19 April 2007 - 05:35
Hi Stefan,
Thanks for the reply. I used the VoiceWarmUp method of logging the uninstall.
I shall try with '!' as well, and update the post.
Thanks again.
Best regards,
Amit
Thanks again.
Best regards,
Amit
Posted 26 April 2007 - 09:38
Hi Stefan,
There doesn't seem any more helpful data win the ! option for logging.
Amit
Amit
Posted 30 April 2007 - 16:19
So the log ends with the same line?
| MSI (s) (94:F4) [11:56:47:004]: Note: 1: 2727 2: |
Did you enable logging on the command line or via the registry or group policy? I'm not sure the ! parameter works there, only on the command line.
