The InstallScript Project needs .NET Framework 3.0.
I want to add it in Objects but there isn't any .NET to choose.
I need to update the InstallShield so that that would be available? Or I need to do something else?
I use InstallShield 2008.
Thank you,
.NET Framework 3.0 adding
Sevo
, Jun 13 2008 08:50
Posted 16 June 2008 - 11:53
I learned that .NET Objects for InstallScript projects are not installed when installing IS2008, by default. We should download separately or via update.
After installing from the link below, all will be OK.
http://www.acresso.c...nloads_8721.htm
Thank you,
Kind regards,
Thank you,
Kind regards,
