sorting features
lavocat
, Feb 21 2006 13:30
8 replies to this topic
Posted 21 February 2006 - 13:30
My setup has many features displayed in the standard tree of the CustomSetup dialog.
I can sort the list for the default language (changing the display number of the feature table) but not for the other languages. InstallShield generate a mst file for each language.
Is there a common way to do this?
Posted 21 February 2006 - 17:58
Are you saying that the order changes when you select a different language? Or are you saying the order is always the same but you would like to set the ordering language dependent?
Posted 21 February 2006 - 19:58
the order is always the same but I would like to set the ordering language dependent
Posted 22 February 2006 - 10:26
I don't think that's possible with InstallShield's help using the FeatureTree dialog. It may be possible by tweaking the generated language transforms manually.
Posted 22 February 2006 - 10:50
No way to use checkboxes for the selection,
No way to sort the tree... We have more than 120 features displayed in the tree and 6 languages
So I'll try to use automation with ISWiAutomation
Thank you Stefan
Thank you Stefan
Posted 22 February 2006 - 21:36
If you're prepared to learn the MSI database APIs (MsiDatabaseOpenView() etc.) this could be done at run-time - after the transform is applied. Make sure the custom action is scheduled before the costing process.
Posted 08 March 2006 - 12:24
Following your advice, I've made a CA (InstallScript code) which sorts Features at run-time: I change only the "Display" fields of the Feature table.
Everything seems to be ok but wanna be sure this is reliable at 100 %
I use this way:
for each record returned by a select I do:
MsiViewModify(hView,MSIMODIFY_DELETE,hRecord)
MsiViewModify(hView,MSIMODIFY_INSERT_TEMPORARY,hRecord)
I'm not able to use MSIMODIFY_UPDATE instead of MSIMODIFY_DELETE and then MSIMODIFY_INSERT_TEMPORARY
Why?
I use this way:
Why?
Posted 08 March 2006 - 20:45
The method is correct, first delete than insert a temporary record. You can't just update the record because the database is opened read-only, and a function like UPDATE_TEMPORARY doesn't exist. (Please don't ask why DELETE does work, instead of a DELETE _TEMPORARY...)
For that matter: the changes are not saved in the cached copy of your MSI file, so you've got to re-execute the CA in maintenance mode.
Posted 09 March 2006 - 10:40
Thank you Zweitze!
If someone needs the code, just ask for it: chrismertens32@hotmail.com
