If I want to debug some change I made in the script I can always put a "Display Message" box in the script to look at some variable etc.
But is there a standard msi command that I can put in the script that logs a text to logfile produced at installation? In that way it can always be enabled.
I have a custom action, that can be used for this. But maybe there is a more standard approach that I missed.
BR Ulf
Custom log messages to MSI log file
uljo2
, Sep 29 2008 14:00
Posted 29 September 2008 - 14:22
You can use the MSI log itself for this. Google for 'Session.Message'.
Posted 29 September 2008 - 15:23
| QUOTE (VBScab @ 2008-09-29 14:22) |
| You can use the MSI log itself for this. Google for 'Session.Message'. |
Thanks, I found it. Google is good but you must search with the right words.
I used some "Call VBScript from embedded code" in my installer tool using this code snippet.
Dim recordLogText
Set recordLogText = Session.Installer.CreateRecord(1)
recordLogText.StringData(1) = "Runnig this custom action"
Session.Message &H04000000, recordLogText
Ok I thought there an even easier solution, but this one will do. It's better than using my ca.dll, passing msi handle and stuff.
/Ulf
Posted 29 September 2008 - 15:32
| QUOTE (uljo2 @ 2008-09-29 14:23) | ||
There sort of is. I have this wrapped up in a class, which I append to any script which needs it. Then I just instantiate an object for that class (let's call it 'clsMSILog') and then just do 'clsMSILog.LogEntry = "some text or other" '
No need to remember constant values, syntax, nothing...
