access denied when calling a DLL function
legalla
, Oct 16 2003 09:35
Posted 16 October 2003 - 09:35
I have a setup which install several NT services. I have build a library that create a user account for the services on a domain or a server name given by the user. This function is called on the OnInstalled event of the service. It works fine but I have upgraded my setup from developer 7 to developer 8 and now I have the message "access denied" when creating a user on a domain.
I have tried several thinks and finally I put the function call in OnFirstUIBefore and then it works ?!?
I don't understand why. It seems that the setup has not always the same "privileges".
Can you explain this strange behavior ?!?
I have submit a request to InstallShiedl Support but I have still no answer. They told me to install Service Pack 2 but it still not works.
Is there someone to help me ?!?
Annie Le Gall
Software Developer
Posted 16 October 2003 - 18:29
I'd recommend performing a MSI Diff of the two packages to see what's different.
Posted 17 October 2003 - 07:36
I found the MSI Diff program and I use it to compare the different package but I don't know how to analyse it.
It seems that the process that was created to manage the OnInstalled event has not the same privileges. I saw in Developer that there is a custom action named OnFeaturesInstalled with the property "Deferred execution in system context". And I saw that if I put my function call in the OnGeneratingMsiScript it works. And the corresponding custom action has the property "Immediate execution". May be a coincidence.
I have attached the MsiDiff results.
Thank you for your help.
Posted 17 October 2003 - 10:17
I have add a function in my DLL to get the user name. Then I saw that when the AddUser function fails, the user name is SYSTEM and when the AddUser function succeeds, the user name is my log on user.
Very strange isn't ?
