We upgraded a perfectly working IS 603 project to IS 702 and are having problems using script-defined variables in our registry and destination folders ever since.
Any help would be greatly appreciated on these two issues:
1) Where are the script-defined folders now? In IS 603, they used to be in the File Groups | Destination. In IS 702, best I can figure, you have to create a component, add files to the component and create the user-defined folder through the GUI in the bottom window.
Then through IS script, add FeatureSetTarget (MEDIA, <szCustomerFolder>, szAppPath) statement.
2) We use the same statements in our registry. We created a registry component since you can no longer link a registry set to more than 1 file group (component) any longer. So we created a component of just registry entries and added them as subfeatures to every feature. In our registry, we used a script-defined variable <szAppPath> that was set in IS script with ComponentSetTarget (now FeatureSetTarget) but that no longer works. A blank path is entered into the registry now.
I've tried IS support which I found to be very unhelpful on the first attempt.
