My installer requires Outlook to be closed before setup can proceed. Is there an easy way with InstallShield Express X to find if Outlook is running and display a message that will have option Close, Retry and Ignore.
Checking to see if process is running
kajal_shah16
, Oct 14 2004 21:13
Posted 15 October 2004 - 15:59
You would have to write a custom action for this. If you ned to close Outlook because you want to replace a file that Outlook uses, a dialig should be displayed automatically, and/or a reboot will be requested at the end of the install.
