I need to find out whether a specific component has been installed previously. I need this information so that I can pop up a message to the user. The ComponentGetData method allows me to know whether the component has been selected but that doesn't help me.
How can I acheive this?
Thanks in advance for any pointers
Sasi
Finding out whether a component is installed
kvsasi
, Nov 19 2002 20:59
Posted 19 November 2002 - 21:10
Well, during an install you can always check "ComponentIsItemSelected (MEDIA, "nameOfComponent");"
If TRUE then the item is either installed or going to be installed, depending on where you check it.
Or, if I'm running a patch I just check for the presence of a file. If you have properietary files that would have been put down with the component use "if (Is(FILE_EXISTS, TARGETDIR + "\\YourFile.dll")) = TRUE then"
HTH
HTH
Posted 20 November 2002 - 00:14
For future reference, I save off the component selections in the registry, so I can re-read them during an update/re-install and take the appropriate actions.
