actually I´m working on a setup project which did already exist as an ISWI-project. I find the ISWI very inflexibly (put CA´s in the correct order, using properties, ....).
Until now I created my own setup projects under IS6 Prof. And I found it very smart :-)
Why should I use ISWI if I only want to copy some files in directories, make some registry entries and want to actualize the present files with newer ones?
The author of this ISWI project told me that he wanted to use the "new windows installer technique". But until now I only see disadvantages for that what I want to do.
Ralf
