In a recent project I needed to create an install which had a total of ten individual seperate application
exes. Inorder to create an uninstall entry for each exe
I created a seperate file group and component folder for each exe and created lists to hold the app name, app exe path and exe version number. The script code does the job nicely. It creates all required uninstall entries in the Add/Remove Programs list. Inorder to update to a newer exe I removal of the older exe through here is recommended. And it works fine. I can remove all the exes however when I arrive at a particular one for some reason Uninstaller informs me that it can't remove this exe because it detected it is in use. But my main application which calls this one is not running at all.
does any one have any idea whats going on?
Any suggestions or ideas are welcome.
Thank you for your attention.
Uninstall issue
dan
, Apr 24 2001 16:01
