I have a minor problem with an install script. In most cases the component list used on SdAskOptions appears normally (two choices), however I've been able to make 4 choices appear just by going back and forth in the setup script. The two 'new' choices are really just an alternate set based on a variable.
Ie, if var=1, display choices A and B.. if var=2 display choices C and D. The glitch is that A, B, C, and D appear after going back and changing a couple options in setup.
Is there a way to reset the component list prior to building it with ComponentAddItem each time?
Much thanks,
Michael
SdAskOptions - component list appears twice
mstembri
, Aug 25 2003 22:37
Posted 26 August 2003 - 13:50
No. You would have to create a new component list. Alternatively you could set the unwanted entries to invisible.
Posted 26 August 2003 - 14:00
How do I set script-generated components (A, B, C, D above) to invisible?
Posted 26 August 2003 - 14:10
Nevermind I found your post in Usenet from 1998: USENET: installshield.is5.file-transfer :: Feb 10, 1998
ComponentSelectItem(MEDIA, szComponent, FALSE); // unselct component, so it dowsn't get installed
ComponentSetData (MEDIA, szComponent, COMPONENT_FIELD_VISIBLE, FALSE,""); //hide it
This should help.
This should help.
