Hello.
I have a regular and simple installation .msi package file in English language.
My job is to update it to support of multiple languages therefore I embedded multiple different languages transforms into main .msi file.
My question: is it possible to see which transforms are embedded in a main .msi file using Orca or similar tools? And if it is possible, how can I programmaticly change one property value (more exactly: one localized string of dialog title), which is set in a transform file?
Thanks in advance.
Best regards
Andreo
transform files embeded in a package
jamsek19
, Jan 08 2010 14:07
Posted 09 January 2010 - 12:03
Hi Andreo,
it is not possible to change an existing transform; you must create a new transform to change the title of the dialog. It is also possible to create a 2nd transform with the new title and apply these after the old transform.
To see which transforms are embedded into one msi, use the script wisubstg.vbs, which is included in the msi sdk or windows sdk. You'll find the script at %programFiles%\Microsoft SDKs\Windows\v7.0\Samples\sysmgmt\msi\scripts.
HTH
HTH
Andreas Kerl
Inside Windows Installer 4.5
ISBN 3-86645-431-7
Posted 11 January 2010 - 08:02
Thanks for reply.
I have another question: how and where exactly is a transform stored if transform is embedded in a .msi package?
Thanks in advance.
Andreo
Thanks in advance.
Andreo
Andreo
Posted 11 January 2010 - 17:15
You're welcome
A transform is stored as a substorage. Look here: http://www.installsi...dlang/index.htm
LG
LG
Andreas Kerl
ISBN 3-86645-431-7
Posted 12 January 2010 - 10:41
Thank you for replay.
I saw mentioned page before and that's works just fine for me. I use that procedure.
Actually I'm creating a .msi package with Wix utility. To make a transform file I use Wix tool torch.exe.
So my procedure is:
1. compiling source code
2. linking as many times as I have different languages
3. creating transforms
4. embedding transforms into main .msi package
5. update language information in Summary information of main .msi package.
Point 2 and 3 takes pretty long specially because transforms differ only in few strings and language code.
Well, I didn't understand how transforms works
and therefore I was searching to do my job faster. I was investigating how to do some kind of hack to make all my transforms faster. In vain...
Thanks again for info.
Best regards
Andreo
So my procedure is:
Best regards
Andreo
Andreo
