I tried to build cab file from command line using ISCab.exe. I used the command as given in the help files.but while executing the command it showed the error "Could not open cab file".then i created a dummy cab file in the same location as the ini file and again run the command.It showed the error "could not open HDR file". But in the help files nothing is mentioned about the format and contents of the HDR files. In help its given that running the command is enough to add the files and nothing is said about creating dummy cab or hdr file. Can anyone help in this regard i.e how to resolve this error?
ISCab.exe
vishnub
, May 03 2005 14:56
Posted 03 May 2005 - 17:34
ISCab.exe is for (pure) InstallScript projects, not for "InstallScript MSI" or "Basic MSI" projects.
