I wrote an installscript function which should rename a subfolder in a previously installed version. When my new setup runs a custom action should invoke the function before the major upgrade of my new setup removes the original subfolder.
My problem is when/how can I correctly call this function? When I sequence my custom action after 'InstallValidate' then I get a transaction record script error and when I sequence it after 'StopServices' then it get's called, but my old version has then already been removed.
I'd would be very thankful for a hint!!!
Any conditions to consider?
Renaming of folders and files before major upgrade
hrms
, Aug 02 2010 07:37
Posted 02 August 2010 - 08:18
It sounds like your CA is sequenced to run before the RemoveFolders standard action. Move it to a position just before that.
Edited by VBScab, 02 August 2010 - 08:19.
Posted 02 August 2010 - 08:46
Just before RemoveFolders is too late, because the files and folders I need to preserve are deleted in the RemoveExistingProducts action. It's a major upgrade that performs a full uninstallation before the installation.
